Community Member
cisco 1721 router problem
Dear,
Yesterday, i faced problem in router. I saw on router only pwr led blink I ping router ip giving request timed out Then i reboot my router & tired to ping it's working fine but what was the problem in router. How can i check. pl.give me sollution.
Thanks in advance.
Re: cisco 1721 router problem
Upendra,
Did you check the logs before rebooting the router. Do you have the logs with you. As per the explanation that you gave, it could be that router's interface hanged or the IOS got hanged and when you rebooted the router, they both reinitialized and the things started working. Without checking the logs its very hard to tell you the exact reason.
-amit singh
Community Member
Dear
can you tell me how can i check log.which command useful for this. i think show log
i tried but there is no log related to ios & other interface.
Community Member
Dear
I want to know. what was the reason for the same. pl. give me sollution
Hi Upendra,
you find any logs when you restarted the router, b4 restarting the router, if you face such of problem, you should always check the logs "show logging", that will help you to troubleshoot in most of the time. so next time when you face such kind of probz, juz see the log, because once you restart the router, all the logs getz cleared, as it is not stored on the router permanently.
Community Member
Dear
as per your suggestion there is no way to check what was the problem in router.
YES, you can't come to know unless you check the log b4 rebooting the router.
Community Member
When cisco router get hang, even we can not enter into the router. it wont allow Console also. So how come we can check Log
Hi Suresh,
upendra has never mentioned that the router got hang, he has just mentioned that ping came with an reply "Request timed out", that doesn't mean that router got hang. so it always a best practice that you see the log b4 rebooting the router or a switch. that will certainly help you to identify the problem.
149
