cisco 1721
I have a cisco 1700 router that I would like to connect to my Verizon Actiontec router and the actiontec is 192.168.1.1 how would I be able to access the internet? I do have an 4 port hwic card.
1 REPLY
Hi there,you want to place
Hi there,
you want to place the 1700 router in your LAN behind your Actiontec router, did I get this right?
So, you need to configure your router interface connected to the Actiontec with IP network 192.168.1.0 (i.e. IP address 192.168.1.2) and a static default route. If you want to use DNS from your Cisco 1700 in your internal networks, you can configure the router as a DNS server as well. Here is an example:
interface g0/0
ip address 192.168.1.2 255.255.255.0
no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip dns server
ip name-server 192.168.1.1
Additionally, you need to configure static routes on the Actiontec router for your internal networks used behind the Cisco 1700, pointing to the 192.68.1.2 as next-hop address. Also, your Actiontec needs to do NAT to connect its 192.168.1.0 network to an external public network.
Hope that helped.
Cheers, Dennis
Please rate helpful posts! Thank you.
36
