Community Member
Cisco 1801 & Etherchannels
Can somone please tell me if its possible to setup a Cisco 1801 for etherchannels to a Cisco 3550 switch?
Ross.
2 ACCEPTED SOLUTIONS
Re: Cisco 1801 & Etherchannels
It seems like 1801 does not support Etherchannel configuration. The
etherswitch module on 1801 is similar to HWIC-4ESW/HWIC-9ESW which do not
support etherchannel either.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/prod_qas0900aecd802
a9470_ps5854_Products_Q_and_A_Item.html
Here is a document that describes Layer 3 Etherchannel support on ISR
platform.
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_white_paper09
00aecd806f698a.pdf
Hope this helps.
NT
That does seem like a possibility. Other option is to use EIGRP that
supports even un-even cost load balancing.
NT
platform.
00aecd806f698a.pdf
Hope this helps.
NT
Community Member
If it doesn't support Etherchannels I was thinking I could use maybe up to four of the fastethernet ports on the 1801 which are then plugged into a Cisco 3550 switch and put each of those four fastethernet ports into their own vlan and setup OSPF to do the load balancing. Can someone suggest if this is possible?
Ross.
NT
494
