Cisco 1841 Max 1.5MB/s between Fa0/0 and Fa0/1
Hello, this is my first post and I have been banging my head against a wall for days trying to figure out this issue. I have a Cisco 1841 running the latest ROMMON 12.4(13r)T5 and IOS ADVIPSERVICESK9-M 15.1(4)M6. Via CLI (I'm studying for CCNA and despise GUIs anyway) I have configured a basic single NAT'd, DHCP setup. Topology: {ISP} --> {Motorola SB6141} --> Fa0/0 {Cisco 1841} Fa0/1 --> {My Mac}. For the internetwork, all connections are Cat5E/Cat6. I know that the 1841 is not a powerful device, but that in ideal situations it should be able to support 38 Mbps or 4.75 MBps.
Situation: When the SB6141 is plugged directly into my Mac, I see the rated throughput of 50/10 Mbps. When the 1841 enters the equation, I only get 1.4 MB/s up and down. What I've tried: SB6141 doesn't have a way of configuring it AFAIK, but the Fa0/0 port it connects to is set to auto speed and auto duplex. A sh int fa0/0 shows that it has negotiated full-duplex and 100Mb/s. Fa0/1 is auto speed and auto duplex and in either topology it negotiates to full-duplex and 100Mb/s. I have tried manually setting both interfaces to full/100 and that made no difference. When a download hits the 1.4 MB/s mark, brief or sustained, the sh cpu process history for the 1841 shows that it is maxing out at 100%. I have OSPF running, but I had the same issue prior to incorporating that. Here is my config:
Elway#sh run
Building configuration...
Current configuration : 2033 bytes
! Last configuration change at 21:34:11 UTC Fri Jan 31 2014 by XXX
version 15.1
hostname Elway
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
no ip source-route
ip dhcp excluded-address 10.0.24.1 10.0.24.50
ip dhcp pool mileHIGH
import all
network 10.0.24.0 255.255.255.0
default-router 10.0.24.1
dns-server 75.75.75.75 75.75.76.76
ip cef
ip domain name XXX
ip name-server 75.75.75.75
ip name-server 75.75.76.76
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO1841 sn FTX0905W15R
archive
log config
  hidekeys
username XXX privilege 15 secret 4 XXX
redundancy
ip tcp synwait-time 10
interface FastEthernet0/0
description Comcast-Link
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
no ip route-cache
ip tcp adjust-mss 1452
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
description LAN
ip address 10.0.24.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat inside
no ip route-cache
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
interface Serial0/1/0
no ip address
shutdown
router ospf 1
network 10.0.24.0 0.0.0.255 area 0
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 10.0.24.0 0.0.0.255
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
end
Everyone's tags (1)
1 ACCEPTED SOLUTION
Bronze
Re: Cisco 1841 Max 1.5MB/s between Fa0/0 and Fa0/1
Try removing all statements from your Fa interfaces except the IP address and NAT statements an see what happens. You can also leave the tcp mss adjust as it only involves the tcp 3-way handshake and shouldn't cause every packet to be inspected.
You need to avoid CPU involvement a such as possible on this platform.
Erik
Sounds like you may have mtu issues punting the traffic to CPU. I see you have tcp mss set on the Comcast link. I think what is occurring may be your LAN being 1500MTU and as it hits your WAN the traffic is fragmented to 1452 (something done in CPU).
Have you tried removing that mss setting or changing mtu on your PC to limit fragmentation via your router?
Bronze
Erik
Take ip virtual assembly out. Should be better then.
Hi Erik,
Thanks for your response. I did as you recommended and slowly pieced things back together. I discovered that the "ip flow" entries on both interfaces were causing packets to go from CEF/fast switched to process switched for some reason, maxing out the CPU. I managed to get the 1841 to handle the rated 60/10Mbps after that - it even maintained close speeds after applying a standard auto secure CBAC (IOS Classic Firewall).
Thanks to everybody for their tips!
Take care,
Jordan
Bronze
You're welcome
718
