cisco 1841 router, corrupt cookie (i think)
dhrumant_g
I have an 1841 router and it gets stuck, i'm hoping someone can help me fix this as i think its a corrupt cookie:
System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 processor with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
program load complete, entry point: 0x8000f000, size: 0x10f59b4
Self decompressing the image : #################################################
################################################# [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X00020000 Crypto module pools
0X0020 0X00035000 Card in slot 0
0X0020 0X00035000 Card in slot 1
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 19611641 bytes to IO Memory.
PMem allocated: 240123904 bytes; IOMem allocated: 28311552 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(3b), REL
EASE SOFTWARE (fc3)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 08-Dec-05 13:27 by alnguyen
Image text-base: 0x60088408, data-base: 0x61A80000
Port Statistics for unclassified packets is not turned on.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
----------------- it gets stuck here --------------------
I can get to rommon and when i type cookie from there, this is what i get:
http://nopaste.com/p/ak3mTv7l8
when i compare it to one from a working 1841 (I have 2 of them), it seems this one is corrupt.
Here is cookie from the working 1841:
http://nopaste.com/p/aC8prydanb
if someone could help me get this router going again, it would be much appreciated.
8 Replies 8
Peter Paluch
The following link contains a few hints how to possibly repair a damaged cookie. Note that all information there is completely unwarranted and may well result in frying your router for good. Nevertheless, as it is currently unusable anyway, you may give it a try.
http://puck.nether.net/pipermail/cisco-nsp/2005-January/015914.html
If you need more information please contact me by my email. You can find it in my profile.
Best regards,
Peter
i've tried it also by leaving the first line of the cookie intact and replacing the rest with the working one, that doesn't work either, it gets stuck in the same place.
can you pleas share me the procedure how to fix the cookie for 1841 router in tridipraj@gmail.com
Langolasnet
I have been having the same issue on my 1841 here at home, I was wondering if you were able to resolve this yet? I'm at the point where I need to fix the cookie too.
No sorry, I have not been able to fix it yet, i'm still trying though. I'm hoping someone on this forum will come to our rescue. =)
Can you re-post a link to your working cookie? I might be able to get mine working with a proper template. I have my mac address saved from old logs and a few other items.
I have left the router at home so i won't be able to post it till tomorrow or later.
Which part of it is the MAC address anyway?
