Cisco 1921 default route not working
Hi:
I'm new to Cisco routing, and I'm having trouble with an aparently very easy configuration. I have a working LAN1 (192.168.1.0/24) with an standard DSL router (192.168.1.254). I have another LAN2 (10.10.10.0/24), and I want to use a Cisco 1921 to route between the two LANs, giving internet access to hosts in LAN2 through standard router in LAN1.
The problem is that I'm not able to ping from LAN2 to hosts in LAN1, and obviously hosts in LAN2 can't access internet.
Please, can someone tell me what is wrong is this simple configuration?
I'm attaching the configuration.
Thanks in advance.
acampbell
Miguel,
A real basic config would be :-
int g0/0
desc ***LAN 1***
ip address 192.168.1.253 255.255.255.0
no shut
int g0/1
desc ***LAN 2***
ip address 10.10.10.254 255.255.255.0
no shut
ip route 0.0.0.0 0.0.0.0 192.168.1.254
Your devices on LAN2 should be using 10.10.10.254 as their default gateway.
You WILL ALSO NEED TO ADD A STATIC ROUTE ON YOUR OTHER ROUTER
10.10.10.0 255.255.255.0 NEXT HOP 192.168.1.253
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi Alex:
The configuration I included in my post I think is according to what you're saying, and of course host in LAN2 are using the correct gateway.
I don't have a static route in LAN1 router for reaching LAN2, because I'm using NAT in LAN2 router (overloading), so there is no packets with 10.10.10.0/24 destination addresses in LAN1. If I understand well NAT working with overloading all traffic in LAN1 with destination LAN2 would have 192.168.1.111 as destination address.
This is resume of the posted configuration:
interface GigabitEthernet0/0
ip address 10.10.10.252 255.255.255.0
ip access-group 103 in
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.1.111 255.255.255.0
ip access-group 100 in
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.254 permanent
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 100 permit icmp any any echo
access-list 100 permit icmp any any traceroute
access-list 100 permit icmp any any unreachable
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.111 eq telnet
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.111 eq 22
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.111 eq www
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.111 eq 443
access-list 100 permit tcp 192.168.1.0 0.0.0.255 host 192.168.1.111 eq cmd
access-list 100 deny   tcp any host 192.168.1.111 eq telnet
access-list 100 deny   tcp any host 192.168.1.111 eq 22
access-list 100 deny   tcp any host 192.168.1.111 eq www
access-list 100 deny   tcp any host 192.168.1.111 eq 443
access-list 100 deny   tcp any host 192.168.1.111 eq cmd
access-list 100 deny   udp any host 192.168.1.111 eq snmp
access-list 100 deny   ip any any
access-list 103 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.252 eq telnet
access-list 103 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.252 eq 22
access-list 103 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.252 eq www
access-list 103 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.252 eq 443
access-list 103 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.252 eq cmd
access-list 103 deny   tcp any host 10.10.10.252 eq telnet
access-list 103 deny   tcp any host 10.10.10.252 eq 22
access-list 103 deny   tcp any host 10.10.10.252 eq www
access-list 103 deny   tcp any host 10.10.10.252 eq 443
access-list 103 deny   tcp any host 10.10.10.252 eq cmd
access-list 103 deny   udp any host 10.10.10.252 eq snmp
access-list 103 permit ip any any
Finally I found the problem. It was a mistake in last line of ACL 100. Begginer's mistake. Thanks.
