Cisco 1941w not able to connect to the Internet
I have been trying to setup the Cisco 1941w at my company for use as a wireless router. Once the router is up and running, I have to route traffic to a Websense V5000 appliance connected to the router. The connection to websense comes later, I haven't even been able to connect to the internet via the Wired connection or Wireless AP. I'm not an expert in networking, please excuse the stupid mistakes.
I have looked at a few posts regarding this router and have tried implementing some of the solutions presented online, but haven't been successful so far. It would be great if someone could give a few pointers. Below is my router and AP config. Only relevant sections shown.
Router Config
ip dhcp excluded-address 20.30.50.1 20.30.50.10
ip dhcp pool DHCPPOOL
network 20.30.50.0 255.255.255.0
default-router 20.30.50.1
dns-server 20.30.50.2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0     //Connected to the outside WAN
ip address 70.35.55.106 255.255.255.248     //static IP provided by ISP
ip access-group In_From_WAN in
ip access-group Out_To_WAN out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
ip verify unicast reverse-path
duplex auto
speed auto
no cdp enable
no mop enabled
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
ip address 20.30.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no cdp enable
no mop enabled
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
no ip address
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/1/7
no ip address
interface Vlan1
description $ES_LAN$
ip address 20.30.50.1 255.255.255.0
ip nat inside
bridge-group 1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 135 pool ovrld overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip access-list extended In_From_WAN
permit udp any host 70.35.55.106
permit tcp any host 70.35.55.106
permit tcp any any established
permit ip host 70.35.55.106 any
permit icmp 70.35.55.0 0.0.0.7 any
ip access-list extended Out_To_WAN
permit ip 20.30.0.0 0.0.255.255 host 70.35.55.106
permit ip 20.30.50.0 0.0.0.255 host 70.35.55.106
permit ip 20.30.10.0 0.0.0.255 host 70.35.55.106
permit tcp 20.30.50.0 0.0.0.255 host 70.35.55.106
access-list 135 permit ip 20.30.10.0 0.0.0.255 any
end
Access Point Config
ap#show run
Building configuration...
dot11 syslog
dot11 ssid example_ssid
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 ***************************
username ********* privilege 15 secret 5 $1$jjR3$QukCvHw99kL9mmE5LLW2c1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
ssid example_ssid
antenna gain 0
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 20.30.50.3 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
end
I tried to ping various interfaces from the Router and the AP. This is what I've observed.
When I login to the Router:
I am able to ping 20.30.50.1 (vlan1), 20.30.10.1 (ge0/1), 20.30.50.2 (bvi1 on ap)
NOT able to ping 70.35.55.106 (ge0/0)
When I login to the Access Point (service-module wlan-ap 0 session):
I am able to ping all the interfaces mentioned above, including the ge0/0 - 70.35.55.106
Users are able to connect to the AP via the example_ssid and get the expected IP address (20.30.50.11 onwards).
Also, "show ip nat trans" on the router does not show anything.
Appreciate any suggestions.
276
