02-06-2012 05:37 PM - edited 03-07-2019 04:45 AM
Can someone walk me through the steps on how to configure my serial modules on my 2600 and 3640? Each router has the WIC-2T with two cables connecting them. I tried to ping one router from the other, but no luck. Serial IP address I just made up, this is my home lab, so if I messed those up some how, please let me know...
Here is the running config for each rotuer:
2610:
Current configuration : 1071 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname Router
boot-start-marker
boot system flash
boot-end-marker
no logging on
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.3.1 192.168.3.150
ip dhcp pool 192.168.3.0/24
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
dns-server 192.168.2.127 192.168.2.128 8.8.8.8
username woodjl1650 privilege 15 password 0 henry999
interface Ethernet0/0
ip address 192.168.3.1 255.255.255.0
half-duplex
interface Serial0/0
ip address 10.0.1.2 255.255.255.0
interface Serial0/1
no ip address
shutdown
no ip http server
ip classless
ip route 192.168.2.0 255.255.255.0 192.168.3.0
ip route 192.168.2.0 255.255.255.0 10.0.1.0
ip route 192.168.3.0 255.255.255.0 192.168.2.0
ip route 192.168.3.0 255.255.255.0 10.0.1.0
snmp-server community public RO
snmp-server community private RW
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
end
3640:
Current configuration : 1950 bytes
version 12.2
hostname 3640-Internet
boot system flash c3640-ik9s-mz.122-40a.bin
memory-size iomem 25
ip subnet-zero
ip cef
ip domain-name www.jkkcc.com
ip name-server 192.168.2.127
ip name-server 192.168.2.128
ip dhcp excluded-address 192.168.2.1 192.168.2.150
ip dhcp pool 192.168.2.0/24
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 192.168.2.127 192.168.2.128 8.8.8.8 127.0.0.1
call rsvp-sync
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
ip address 10.0.1.1 255.255.255.0
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Ethernet1/0
no ip address
shutdown
half-duplex
interface Ethernet1/1
no ip address
shutdown
half-duplex
interface Ethernet3/0
no ip address
shutdown
half-duplex
interface Ethernet3/1
no ip address
shutdown
half-duplex
ip nat inside source list 15 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.2.128 25 interface FastEthernet0/0 25
ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 80
ip classless
ip http server
ip http authentication local
access-list 15 permit 192.168.2.0 0.0.0.255
snmp-server enable traps tty
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
Solved! Go to Solution.
02-06-2012 06:19 PM
Ok, encapsulation looks good. You need to clock the DCE side of the cable.
sh contr se0 will tell you which side is DTE and which side is DTE
On DCE site
inte s0
clock rate 2000000
if this does not work try
clock rate 64000
02-07-2012 06:39 PM
half-duplex
Is this interface in up and up mode?
sh ip int bri
02-06-2012 06:01 PM
Are the physical interfaces in up and up mode? Can you issue this command on both routers and post them here?
"sh ip int bri"
02-06-2012 06:04 PM
It show the protocol as down, how do I enable it?
2610:
Ethernet0/0 192.168.3.1 YES NVRAM up up
Serial0/0 10.0.1.2 YES manual up down
Serial0/1
3640:
3640-Internet#sh ip int bri
FastEthernet0/0 68.224.240.31 YES DHCP up up
Serial0/0 10.0.1.1 YES manual up down
FastEthernet0/1 192.168.2.1 YES NVRAM up up
Serial0/1 unassigned YES NVRAM administratively down down
Ethernet1/0 unassigned YES NVRAM administratively down down
Ethernet1/1 unassigned YES NVRAM administratively down down
Ethernet3/0 unassigned YES NVRAM administratively down down
Ethernet3/1 unassigned YES NVRAM administratively down down
3640-Internet#
02-06-2012 06:08 PM
Can you make sure encapsulation is the same for both interfaces? They should be HDLC by default. "sh int se0" on both routers
Are you using a serial interface to connect them together? what type cable is that?
02-06-2012 06:15 PM
I am using two DTE cables to connect the two...
3640:
3640-Internet#show interface serial 0/0
Serial0/0 is up, line protocol is down
Hardware is DSCC4 Serial
Internet address is 10.0.1.1/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:00:30
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3 packets output, 72 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
2 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
2610:
Router#show interface serial 0/0
Hardware is PowerQUICC Serial
Internet address is 10.0.1.2/24
Last clearing of "show interface" counters 00:02:19
Conversations 0/1/256 (active/max active/max total)
10 packets output, 240 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
18 carrier transitions
02-06-2012 06:19 PM
On DCE site
inte s0
clock rate 2000000
clock rate 64000
02-06-2012 06:31 PM
One last question... since there are two ports on the interface card, can I connect the two routers by the two WIC ports? Would that have any advantage?
02-06-2012 06:42 PM
Yes, you can. Put the other interface in a different subnet.
Not in this case. If you had lets say 2 T1 connecting to the same provider, you could bundle the 2 together to get more bandwidth for a total of 3Mb.
1.5x2=3
02-06-2012 06:29 PM
Is it working now?
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
02-06-2012 06:41 PM
Well I jumped the gun, I can ping from the 192.168.3.1 router (2610) to the 192.168.2.1 router (3640), but not form 192.168.2.1 to the 192.168.3.1....any idea?
02-06-2012 06:48 PM
On the 2610 you need a static route like this:
ip route 192.168.2.0 255.255.255.0 10.0.1.2
on the 3640 you need a static route like this:
ip route 192.168.3.0 255.255.255.0 10.0.1.1
02-06-2012 06:55 PM
on the 3640 I get this:
3640-Internet(config)#ip route 192.168.3.0 255.255.255.0 10.0.1.1
%Invalid next hop address (it's this router)
02-06-2012 07:02 PM
switch them arounf
ip route 192.168.2.0 255.255.255.0 10.0.1.1
ip route 192.168.3.0 255.255.255.0 10.0.1.2
Basically on the 2610 you want to point to the serial interface of the 3640
On the 3640 you want to point to the serial interface of the 2610
02-06-2012 07:10 PM
So do I need to configure each port on the WIC card? Right now, I only have se0/0 configured and not se0/1? I can ping just fine from the 2600 to the 3640...but no success from 3640 to 2600.
02-06-2012 07:17 PM
You only need one serial interface on each router.
but with the static route I provide you. you should be able to ping from both router
if this is for lab use and not production, can you delete all the extra static routes on both routers and test again?
You just need the one I provided you
no ip route 192.168.2.0 255.255.255.0 192.168.3.0
no ip route 192.168.2.0 255.255.255.0 10.0.1.0
no ip route 192.168.3.0 255.255.255.0 192.168.2.0
no ip route 192.168.3.0 255.255.255.0 10.0.1.0
