03-29-2012 04:39 PM - edited 03-07-2019 05:51 AM
I have a 2600 Router series and I cannot remember the Password. I have tried following web pages that state to use control Break on the boot up but its not working. Anyone help on this so I can reset that pw and write erase my configuration file?
Here is my boot up. I have tried hitting control break at the very beginning over and over and then again when at the cold boot it has not worked....
System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 131072 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x1c9468c
Self decompressing the image : #################################################
####### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
00036A 0X000B3B80 C2610XM Single Fast Ethernet
0X00098670 public buffer pools
0X00211000 public particle pools
TOTAL: 0X0035D1F0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 3Mb.
Using 2 percent iomem. [3Mb/128Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(25d),
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 04:49 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2610XM (MPC860P) processor (revision 1.0) with 127627K/3445K bytes of memo
ry.
Processor board ID JAE0728045W
M860 processor: part number 5, mask 2
1 FastEthernet interface
1 Serial interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Slot is empty or does not support clock participate
WIC slot is empty or does not support clock participate
Press RETURN to get started!
*Mar 1 00:00:07.652: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0
, changed state to up
*Mar 1 00:00:16.867: SERVICE_MODULE(Serial0/0): self test finished: Passed
*Mar 1 00:00:31.491: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state t
o up
*Mar 1 00:00:31.491: %LINK-3-UPDOWN: Interface Serial0/0, changed state to down
*Mar 1 00:00:32.541: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/0, changed state to up
*Mar 1 00:00:32.541: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0,
*Mar 1 00:00:33.627: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 1 23:38:52.439: %SYS-5-RESTART: System restarted --
*Mar 1 23:38:52.444: %SNMP-5-COLDSTART: SNMP agent on host HQ is undergoing a c
old start
Solved! Go to Solution.
03-29-2012 05:15 PM
Brian.
What terminal program are you using to connect to the console?
If I remember rightly, Hyperterm had major issues with sending the break command to Cisco consoles, so it almost never worked. Try to download TerraTermPro and use that - it's got a menu option for sending "break", so you don't need to have a key combination.
Once you're in ROMMON mode, password recovery is easy.
Cheers
03-29-2012 04:54 PM
Never done it on this series, but the instructions say just use break, not control-break.
"Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMmon."
On section 4 there is more info if Break does not work.
03-29-2012 05:15 PM
Brian.
Cheers
03-29-2012 05:20 PM
I am using Windowss 7, 64 bit professional and for my terminal I am using tera term web 3.1 the application icon states ttermpro so kind of looked like the pro.
Anyway I found my own fix and it was very odd one I got it from the following web page:
http://www.routergeek.net/general/how-to-simulate-break-key-sequence-in-a-cisco-router/
To simulate the break key sequence, go through the following steps carefully:
1. Connect to the router with these terminal settings:
Baud rate: 1200
Parity: None
Data bits: 8
Stop bits: 1
Flow control: None
You will no longer see any output on your screen, and this is normal.
2. Power cycle (switch off and then on) the router and press the SPACEBAR for 10-15 seconds in order to generate a signal similar to the break sequence.
3. Disconnect your terminal, and reconnect with a 9600 baud rate. You enter the ROM Monitor mode.
those steps got me to Rommon 1 >
I think the normal password reset stuff will work now
Baud rate: 1200
Parity: None
Data bits: 8
Stop bits: 1
Flow control: None
03-29-2012 05:31 PM
I will give you the credit for the answer even though I found it, because you did bring up the Break in Terminal Pro and while I didnt test it that probably would have worked as well. I will test that later to see if it works with my particular router.
