11-26-2006 05:24 AM - edited 03-05-2019 01:01 PM
I have a cisco 2600 and trying to configure some vlan's on that i got the following error on debug:
00:02:16: IP: s=192.168.200.1 (local), d=192.168.200.3 (FastEthernet1/0.20), len 100, encapsulation failed
00:02:16: IP ARP rep filtered src 192.168.200.3 0014.bf59.9f31, dst 192.168.200.1 0009.4364.0410 wrong cable, interface FastEthernet1/0
following goes a 'sh version', 'sh running-config', and debug errors:
Somebody can help-me?`
tanx!
11-26-2006 05:48 AM
Check the Cisco IOS debug command reference
This indicates that another host on the network attempted to inform the router that it is on network 192.168.200.3, but the router does not know that the network is attached to a different router interface/subinterface. The remote host (probably a PC or an X terminal) is misconfigured. If the router were to install this entry, it would deny service to the real machine on the proper cable.
What is the default gateway on this 192.168.200.3 machine.
--Pls rate if this helps--
11-26-2006 07:37 AM
Dear zubairjalal,
The 192.168.200.3 is a linksys srw224g4 swich that the router is atached to. and the default router of the switch is the 192.168.200.1 (the sub-interface router)
I can't see the solution yet.
thanx
11-26-2006 08:13 AM
Hi Denis,
As you mentioned your router is connected to linksys switch. Have you configurd the switchport on linksys router as trunk interface? Because cisco router is expecting tag traffic from vlan 20?
Just confirm the switchport config for linksys switch?
Ankur
11-26-2006 08:17 AM
It didnt work with the port configured to trnk or to vlan 20...
11-26-2006 07:41 AM
.. and sorry but i didn't understand very well what i have to do with your msg..
can u give some advices?
my router does't work in any vlan instead vlan 1
11-26-2006 09:29 AM
Hi Denis,
The error that you are getting is about the encapsulation failed on the port connecting to the router.
The problem that you are facing is that when you are configuring router on stick for inter-vlan routing, you have to configure the switchport connecting to the router as Trunk port and other the router side you have configure the respective sub-interfaces with the proper vlan id's. For example :
interface Ethernet0/0.16
encapsulation dot1Q 16 <-- Vlan ID
ip address 16.0.0.6 255.0.0.0
interface Ethernet0/0.26
encapsulation dot1Q 26 <-- Vlan ID
ip address 26.0.0.6 255.0.0.0
Make sure that you configure the interfaces for all the vlans that you have with teh proper ID's posted above and all the vlans should be allowed on the trunk port. Makre sure that you native vlan mathces at both the ends.
If you want you can paste your router configuration and we will help you to design it for you.
HTH,
-amit singh
11-26-2006 09:50 AM
how do i set the navive vlan on the router?
tnx
11-26-2006 09:53 AM
Hi Denis,
For an example
Under subinterface
encapsulation dot1Q 20 native
Ankur
