Cisco 2800 Internet routing
Sudhir Menon
I have a very typical issue
I want to undersdtand if a Cisco 2821 with 1 Gb DRAM can absorb the whole Internet routing table ,though i understand it wud'nt be an optimum solution and any supporting documents if available
Hello Sudhir,
I haven't a link for this.
Probably an official Cisco answer wouldn't recommend to use a C2821 for handling a full BGP table.
If I remember correctly someone has reported to doing this here in the forums.
The only doubts are about the cpu average usage caused by the BGP process: memory will be enough.
Some tuning of BGP scanner frequency can be needed in order to reduce CPU usage
And of course only if you are receiving a single BGP full internet table and no more.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sudhir,
yes with 1GB RAM the c2821 can host a full BGP table of 270,000 routes and it is able to create a CEF table for all the prefixes.
What you cannot have is capability to forward traffic at GE speeds (full rate)
Hope to help
Giuseppe
Hi Giuseppe
Thanx for your reply do you have any supporting documents mentioning the same if not directly from Cisco
Hello Sudhir,
Hope to help
Giuseppe
This has centianly helped me a lot thank you very much Giuseppe ,I was just hoping to find a document as i had a customer call on this
