Community Member
Cisco 2811 increasing the number of connections
Hi there
On my network most of us times out with the internet connection and I contacted my ISP and he says that we have to increase the number of connections on our router cisco 2811.
1-  How and with command can I do that?
2- where did the isp saw in the ip inspect all command that we were exceeding connections?
Help plz
router 2811>sh ip inspect all
Session audit trail is enabled
Session alert is enabled
one-minute (sampling period) thresholds are [400:500] connections
max-incomplete sessions thresholds are [400:500]
max-incomplete tcp connections per host is 50. Block-time 0 minute.
tcp synwait-time is 30 sec -- tcp finwait-time is 5 sec
tcp idle-time is 3600 sec -- udp idle-time is 30 sec
dns-timeout is 5 sec
Inspection Rule Configuration
Inspection name TRAFFIC_INSPECTI
    tcp alert is on audit-trail is on timeout 3600
    udp alert is on audit-trail is on timeout 30
    ftp alert is on audit-trail is on timeout 3600
    http java-list 21 alert is on audit-trail is on timeout 3600
    tftp alert is on audit-trail is on timeout 30
    cuseeme alert is on audit-trail is on timeout 3600
    h323 alert is on audit-trail is on timeout 3600
    rcmd alert is on audit-trail is on timeout 3600
    realaudio alert is on audit-trail is on timeout 3600
    sqlnet alert is on audit-trail is on timeout 3600
    streamworks alert is on audit-trail is on timeout 30
    vdolive alert is on audit-trail is on timeout 3600
    dns alert is on audit-trail is on timeout 30
    echo alert is on audit-trail is on timeout 30
    fragment Maximum 256  In Use 0 alert is on audit-trail is on timeout 1
    https alert is on audit-trail is on timeout 3600
    icmp alert is on audit-trail is on timeout 10
    telnet alert is on audit-trail is on timeout 3600
    sip alert is on audit-trail is on timeout 30
    skinny alert is on audit-trail is on timeout 3600
    smtp max-data 20000000 alert is on audit-trail is on timeout 3600
Interface Configuration
Interface FastEthernet0/1.92
  Inbound inspection rule is not set
  Outgoing inspection rule is TRAFFIC_INSPECTI
  Inbound access list is 101
  Outgoing access list is not set
*******************************************8
1 REPLY
Community Member
Re: Cisco 2811 increasing the number of connections
Thank you for your question.  This community is for Cisco Small Business products and your question is in reference to a Cisco Elite/Classic product.  Please post your question in the Cisco NetPro forums located here: Forum http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=E0EEC3D9CB4E5165ED16933737822748.SJ3A?page=Network_Infrastructure_discussion  This forum has subject matter experts on Cisco Elite/Classic products that may be able to answer your question.
461
