cisco 2811 with AIM-SSL2 produces 100% CPU load at only 4 Mbit/s throughput
guilty_2
We are using a few Cisco2811's with the AIM-SSL2 hardware encryption module in a private WAN.
This WAN is ethernet based and uses private address space.
To add security, we are using cisco group-VPN with AES-128 encryption. The IOS version is advanced ip services.
Routing is done with OSPF.
According several sources on the cisco site this hardware combination should be able to handle a throughput of 30 -90 Mbit/s.
In effect, we see that the CPU uses 60% at 2 Mbit/s load and almost flatlines at 100% on 4 Mbit/s load.
With a 'show proc cpu' however the biggest individual process uses only 1,5%.
The testscenario at which the 30 - 90 Mbit/s load get reached is a point-to-point Ipsec solution encrypted at 3DES.
Questions:
- Has anyone in the field reached better performance in the scenario we utilize ?
- Did we select the proper hardware or are we using underspecced equipment ? If so, what router should we use to
  reache at least a througput of 20 mb/s ?
15 Replies 15
Peter Paluch
Hello Rob,
This looks as if the router was not using the AIM module at all, or had significant work to do even if the AIM was used and offloaded the crypto operations. The throughput as indicated in datasheets is under ideal conditions but certainly, what you are experiencing is something deserving attention.
One thing to verify is the output of show crypto engine brief and show crypto engine accelerator statistic commands to verify if the AIM module is recognized, enabled and used (the show inventory and show diag may also be useful here although it will only print out the presence of the module in your router but not its usage state).
Another place to check is the running-config for any crypto engine commands - particularly if they are in the "no" form. These commands may deactivate the AIM module and force the crypto operations to be performed by the CPU itself.
Yet another place to look into is the show processes cpu sorted under high traffic load to see which process is consuming the most CPU cycles. That may indicate further the possible cause.
A thing immediately coming to my mind is the MTU issue - IPsec necessarily causes the packets to bloat because of additional encapsulation. If the resulting packets are too big, they need to be fragmented, and that can cause the CPU to spike up. I strongly recommend reading the following document carefully and handling the MTU accordingly:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_white_paper09186a00800d6979.shtml
Best regards,
Peter
Hi Peter,
thanks for your quick reply. Here are some highlights of the proposed commands.
        crypto engine name:  Virtual Private Network (VPN) Module
        crypto engine type:  hardware
        State:  Enabled
        VPN Module in slot:  0
        Product Name:  AIM-VPN/SSL-2
Last 5 minutes:
       933793 packets in                      933793 packets out
          3112 paks/sec in                       3112 paks/sec out
      2982903 bits/sec in                    2961855 bits/sec out
      48599582 bytes decrypted               39232809 bytes encrypted
       1313502 Kbits/sec decrypted            1060346 Kbits/sec encrypted
      1.0:1 compression ratio                1.0:1 overall
Errors:
   ppq full errors         :      506   ppq rx errors           :        0
NR overflow             :        0   pkts dropped            :      506
show inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V06 , SN: FHK124xxx
NAME: "Virtual Private Network (VPN) Module on Slot 0", DESCR: "Encryption AIM Element"
PID: AIM-VPN/SSL-2     , VID: V01, SN: FOC1241xxx
show proc cpu sorted:
CPU utilization for five seconds: 73%/70%; one minute: 73%; five minutes: 70%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
178     6750736 122200048         55  1.59%  1.45%  1.52%   0 HQF Shaper Backg
111      638552    554465       1151  0.23%  0.12%  0.09%   0 IP Input
   2      237820    102147       2328  0.07%  0.13%  0.13%   0 Load Meter
152       38556     15189       2538  0.07%  0.00%  0.00%   0 TCP Protocols
  33       36080    510730         70  0.07%  0.00%  0.00%   0 GraphIt
  19      229612    382633        600  0.07%  0.04%  0.03%   0 ARP Input
I'll also take a look into the MTU link you send me.
Thanks.
Hi Kishore,
the 'testscenario' is the scenario CISCO claims 30-90 Mbit/s throughput is reached. I personally did not verify that
as i am not in a position to change the crypto type in a production situation.
this is the link i am referring to:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/data_sheet_vpn_aim_for_18128003800routers_ps5853_Products_Data_Sheet.html
I am using cisco group VPN, no GRE involved.
Rob,
Thank for posting the information. Your router seems to be spending most of its time handling interrupts which would suggest that no ordinary process switching or process-based packet handling is taking place which is good. However, spending 70% in interrupt context while handling just a few Mbps is still unusually high. The HQF shaper load is completely negligible here.
The counters of encrypted/decrypted traffic in Kbit/s are insanely high... They would suggest that the encryption/decryption speed was roughly at 1Gb/s. I can't see how that can be true - consider clearing the counters using the clear crypto engine accelerator counter command.
Are you running CEF? Please verify that using the show ip cef command. Also please make sure all your interfaces are using CEF - they should not contain any no ip route-cache comands.
Are there any other applications or services running on the router - IP Inspect, ZBFW, TCP Intercept, NAT, IPS/IDS? What IOS version are you using?
Also, has it actually been proven that it is the crypto traffic that causes this load?
Best regards,
Peter
Hi Peter,
i agree the counter is insanely high, might be a bug in the output format.
Looks like there is a factor 1000 difference. So it might have to be bits/sec instead of Kbits/sec.
After clearing the accelerator counters:
        Last 5 minutes:
         101298 packets in                      101298 packets out
           2813 paks/sec in                       2813 paks/sec out
        3584908 bits/sec in                    3590411 bits/sec out
        7878416 bytes decrypted                4067189 bytes encrypted
        1969604 Kbits/sec decrypted            1016797 Kbits/sec encrypted
so no real difference there
sh int fast 0/0 | incl input rate|output rate
  30 second input rate 980000 bits/sec, 1696 packets/sec
  30 second output rate 2286000 bits/sec, 1669 packets/sec
sh int fast 0/1 | incl input rate|output rate
  30 second input rate 3309000 bits/sec, 1642 packets/sec
  30 second output rate 2057000 bits/sec, 1680 packets/sec
show ip cef (some octets censored using x's)
Prefix               Next Hop             Interface
0.0.0.0/0            192.168.xxx.254      FastEthernet0/1.400
0.0.0.0/8            drop
0.0.0.0/32           receive
10.xx.50.0/24        192.168.xxx.254      FastEthernet0/1.400
10.xx.51.0/24        192.168.xxx.254      FastEthernet0/1.400
sh ip int | incl Fast|route
FastEthernet0/0 is up, line protocol is up
  IP route-cache flags are Fast, CEF
FastEthernet0/0.12 is up, line protocol is up
FastEthernet0/1 is up, line protocol is up
FastEthernet0/1.400 is up, line protocol is up
FastEthernet0/1.410 is up, line protocol is up
FastEthernet0/1.420 is up, line protocol is up
FastEthernet0/1.430 is up, line protocol is up
I am not using any of the services you listed.
sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 00:05 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
I am not sure i understand the question if it has been proven the crypto traffic is causing the load.
The only traffic passing this box is traffic going in unencrypted and leaving encrypted. There is some OSPF
running on this box, but as it is a relatively small WAN (about 10 networks) i do not expect OSPF to
be the troublemaker. That also does not show in the CPU load. Most anoying thing is actually that the
show proc cpu output only shows the high load, but not the actual proces causing that load, leaving me with
a big incertainty what is happing on a process level on this router.
Hi Rob,
Most anoying thing is actually that the show proc cpu output only shows the high load, but not the actual proces causing that load, leaving me with a big incertainty what is happing on a process level on this router.
Well, the catch here is that the high load caused by the CPU spending lots of time in the interrupt context. It is not process-based load. From the total load of 73%, only 3% are consumed by processes and the remaining 70% are caused by the router performing some interrupt-based work. The show processes cpu is therefore unable to show any particular process causing the high load because it is in fact no process at all - rather, it is an interrupt handler.
Personally, I suggest (re)visiting the following two documents:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
If my time permits, I can try to set up a simple lab with a couple of 2811 routers and GETVPN to see if I can confirm similar results. However, I do not have AIM modules available, just on-board crypto engines - but that should mean that my performance should not be better than yours, and if it is, there is something VERY wicked going on.
Has the same phenomenon with high CPU been observed on other routers in your VPN?
Best regards,
Peter
Hi Peter,
"Has the same phenomenon with high CPU been observed on other routers in your VPN?"
Yes, all routers in the WAN (and in the same groupVPN) show exact the same behaviour.
Rob,
so let me ask you this. You do get the required throughput when you use 3DES, its only when you use AES that you see the spike .would i be right? As peter mentioned the performance switching on the 2811 should be enough for your requirements. Have you checked if the IOS has any bugs in terms of using IPsec with AES etc. Is it possible to downgrade or upgrade your IOS on just one device and see if it helps.
Also as peter recommended cheking MTU is also a good thing. Are you using GRE as well or just IPsec?
Kishore
Hi Kishore,
Hi Peter,
Peter Paluch
Rob,
So I've made a couple of experiments with 2811 routers running 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(4)M2 IOS. There were no AIM modules in these routers, only onboard VPN modules:
GM-1#show crypto engine brief
                     State:  Enabled
              Product Name:  Onboard-VPN
        Middleware Version:  v1.3.3
          Firmware Version:  v2.3.3
              Time running:  6490 seconds
               Compression:  Yes
                       DES:  Yes
                     3 DES:  Yes
                   AES CBC:  Yes (128,192,256)
                  AES CNTR:  No
     Maximum buffer length:  4096
          Maximum DH index:  0000
          Maximum SA index:  0000
        Maximum Flow index:  2400
      Maximum RSA key size:  2048
        crypto engine name:  Cisco VPN Software Implementation
        crypto engine type:  software
             serial number:  EADF0262
       crypto engine state:  installed
     crypto engine in slot:  N/A
GM-1#
Thy Key Server router relevant configuration:
crypto isakmp policy 1
encr aes
authentication pre-share
group 5
crypto isakmp key asdf address 192.0.2.1
crypto isakmp key asdf address 192.0.2.2
crypto isakmp key asdf address 192.0.2.3
crypto ipsec transform-set ESP-AES-SHA esp-aes esp-sha-hmac
crypto ipsec profile GETVPN-IPsec-Profile
set transform-set ESP-AES-SHA
crypto gdoi group B301
identity number 1
server local
  rekey lifetime seconds 3600
  rekey retransmit 60 number 3
  rekey authentication mypubkey rsa GETVPN
  rekey transport unicast
  sa ipsec 1
   match address ipv4 100
   replay counter window-size 64
  address ipv4 192.0.2.4
interface Loopback0
ip address 192.0.2.4 255.255.255.255
access-list 100 permit ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
Relevant configuration of two Group Member "X" ("X" being 1, 2, 3):
encr aes
group 5
crypto isakmp key asdf address 192.0.2.4
identity number 1
server address ipv4 192.0.2.4
client registration interface Loopback0
crypto map CM-fa0/0 1 gdoi
set group B301
interface Loopback0
ip address 192.0.2.X 255.255.255.255 !
interface FastEthernet0/0
ip address 10.1.X.2 255.255.255.0
duplex auto
speed auto
crypto map CM-fa0/0
interface FastEthernet0/1
ip address 10.0.X.1 255.255.255.0
duplex auto
speed auto
On Fa0/1 interfaces, I had PCs connected running D-ITG as traffic generator. I have been generating one-way UDP flows between PCs 10.0.1.2 and 10.0.2.2, each connected to its own GM router, running it through the GETVPN cloud.
The results were rather surprising:
200 pps, 1428 Bpp, roughly 2.2Mbps: sustained CPU load 14%/13%
400 pps, 1428 Bpp, roughly 4.5Mbps: sustained CPU load 26%/25%
600 pps, 1428 Bpp, roughly 6.8Mbps: sustained CPU load 39%/37%
800 pps, 1428 Bpp, roughly 9.1Mbps: sustained CPU load 50%/48%
1000 pps, 1428 Bpp, roughly 11.4Mbps: sustained CPU load 63%/60%
1200 pps, 1428 Bpp, roughly 13.7Mbps: sustained CPU load 76%/72%
1600 pps, 714 Bpp, roughly 9.1Mbps: sustained CPU load 61%/57%
3200 pps, 357 Bpp, roughly 9.1Mbps: sustained CPU load 93%/92%
(pps = packets per second, Bpp = bytes per packet)
As you can see, I was easily able to go up to 13.7Mbps with large packets quite safely. The 1428-byte IP packets were even fragmented before encryption (I have captured the internal GETVPN traffic and saw ESP packets of alternating sizes slightly above 1300 and 300 bytes).
Naturally, producing smaller packets more often yielded higher CPU loads - compare the last two lines to the 800pps/1428Bpp load at the same throughput.
However, using just plain 2811, I was able to reach much higher throughputs with less CPU load... Your issue really needs further investigation.
Do you believe you could post the entire configuration of the router experiencing the high loads?
Best regards,
Peter
Hi Peter,
passwords and some ip addresses have been anonymized, but this is the whole config.
version 12.4
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname xxx
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 20000
no logging console
no aaa new-model
clock timezone CET 1
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 syslog
ip source-route
ip cef
ip domain name yourdomain.com
ip vrf EXAMPLE1
rd 310:310
route-target export 310:1000
route-target import 310:1000
ip vrf EXAMPLE2
rd 300:300
route-target export 300:1000
route-target import 300:1000
ip vrf EXAMPLE3
rd 280:280
route-target export 280:1000
route-target import 280:1000
no ipv6 cef
voice-card 0
crypto isakmp policy 10
encr aes
group 2
crypto isakmp key somekey1 address 192.168.0.1
crypto isakmp key somekey2 address 192.168.0.2
crypto gdoi group getvpn
identity number 1234
server address ipv4 192.168.0.1
server address ipv4 192.168.0.2
crypto map getvpn-map 10 gdoi
set group getvpn
archive
log config
  hidekeys
description Inside interface
ip address 192.168.252.11 255.255.255.0
ip tcp adjust-mss 1360
load-interval 30
duplex full
speed 100
interface FastEthernet0/0.12
encapsulation dot1Q 12
ip vrf forwarding EXAMPLE2
ip address 192.168.148.201 255.255.255.0
description Outside interface to PE
no ip address
load-interval 30
duplex full
speed 100
interface FastEthernet0/1.400
encapsulation dot1Q 400
ip address 192.168.251.11 255.255.255.0
ip access-group 161 out
interface FastEthernet0/1.410
encapsulation dot1Q 410
ip address 192.168.249.2 255.255.255.248
interface FastEthernet0/1.420
encapsulation dot1Q 420
ip vrf forwarding EXAMPLE1
ip address 192.168.249.10 255.255.255.248
interface FastEthernet0/1.430
encapsulation dot1Q 430
ip vrf forwarding EXAMPLE3
ip address 192.168.249.18 255.255.255.248
router ospf 100
log-adjacency-changes
redistribute static subnets route-map static_routes
network 192.168.251.0 0.0.0.255 area 0
network 192.168.252.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.251.254
ip route 172.25.0.0 255.255.0.0 192.168.252.2
ip route vrf EXAMPLE1 192.168.250.8 255.255.255.248 192.168.249.9
ip route vrf EXAMPLE2 192.168.250.0 255.255.255.248 192.168.249.1
ip route vrf EXAMPLE3 192.168.250.16 255.255.255.248 192.168.249.17
no ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap warnings
access-list 52 permit any
access-list 99 permit 172.25.x.60
access-list 99 permit 172.25.x.61
access-list 161 remark ACL at bootup router is fail closed until policy is loaded-no leak
access-list 161 permit esp any any
access-list 161 permit udp any eq isakmp any eq isakmp
access-list 161 permit udp any any eq isakmp
access-list 161 permit udp any any eq 848
access-list 161 permit ospf any any
access-list 161 deny   ip any any
route-map static_routes permit 10
match ip address 52
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
line con 0
session-timeout 10
exec-timeout 15 0
password xxx
logging synchronous
login
line aux 0
session-timeout 10
exec-timeout 5 0
password xxx
logging synchronous
login
line vty 0 4
session-timeout 60
exec-timeout 15 0
privilege level 15
password xxx
logging synchronous
login
transport input telnet ssh
line vty 5 15
privilege level 15
password xxx
logging synchronous
login
scheduler allocate 20000 1000
ntp access-group peer 99
ntp access-group query-only 99
ntp server 172.25.x.60
ntp server 172.25.x.61
end
Hello Rob,
Thanks for the config! Indeed, your configuration is rather basic - there is nothing special in there. Do you believe you could also post the output of the show crypto gdoi command?
On another note, what is the general nature of the traffic in your GETVPN - is it mostly data transfer or VoIP? I am trying to understand the nature of the flows.
Do you have a TAC contract? We are slowly reaching the limits of what we can try out.
Best regards,
Peter
Hi Peter,
output of show crypto gdoi
GROUP INFORMATION
    Group Name               : getvpn
    Group Identity           : 1234
    Rekeys received          : 101
    IPSec SA Direction       : Both
    Active Group Server      : 192.168.0.2
    Group Server list        : 192.168.0.2
                               192.168.0.1
    GM Reregisters in        : 1271 secs
    Rekey Received(hh:mm:ss) : 01:32:52
    Rekeys received
         Cumulative          : 101
         After registration  : 101
    Rekey Acks sent          : 101
ACL Downloaded From KS 192.168.0.2:
   access-list  deny esp any any
   access-list  deny udp any port = 500 any port = 500
   access-list  deny udp any any port = 500
   access-list  deny udp any any port = 848
   access-list  deny ospf any any
   access-list  permit ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
   access-list  permit ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
   access-list  permit ip 172.0.0.0 0.255.255.255 172.0.0.0 0.255.255.255
   access-list  permit ip 193.0.0.0 0.255.255.255 172.0.0.0 0.255.255.255
   access-list  permit ip 194.0.0.0 0.255.255.255 172.0.0.0 0.255.255.255
   access-list  permit ip any any
KEK POLICY:
    Rekey Transport Type     : Unicast
    Lifetime (secs)          : 32789
    Encrypt Algorithm        : 3DES
    Key Size                 : 192
    Sig Hash Algorithm       : HMAC_AUTH_SHA
    Sig Key Length (bits)    : 1024
TEK POLICY:
  FastEthernet0/1.400:
    IPsec SA:
        sa direction:inbound
        spi: 0x45F31DC(73347548)
        transform: esp-aes esp-sha-hmac
        sa timing:remaining key lifetime (sec): (1627)
        Anti-Replay(Time Based) : 5 sec interval
    IPsec SA:
        sa direction:outbound
        sa timing:remaining key lifetime (sec): (1620)
    IPsec SA:
    IPsec SA:
    IPsec SA:
    IPsec SA:
    IPsec SA:
    IPsec SA:
        sa timing:remaining key lifetime (sec): (1615)
    IPsec SA:
    IPsec SA:
    IPsec SA:
    IPsec SA:
    IPsec SA:
    IPsec SA:
    IPsec SA:
        sa timing:remaining key lifetime (sec): (1614)
    IPsec SA:
i am a local engineer, but i believe the WAN boxes are listed under a global TAC contract. I'll have to
look into that and i will, just in case we don't find the answer.
