04-30-2010 07:35 AM - edited 03-06-2019 10:53 AM
I am trying to find where Cisco 2821 saves crashinfo file and how do i retrieve it.
This is urgent, can anybody please help me with the information.
Thanks in advance.
Manmohan.
04-30-2010 07:37 AM
Hi Manmohan,
It should be saved on the flash
Reza
04-30-2010 07:42 AM
Hello Reza,
Unfortunately i am not finding it. By any chance do you have any reference link.
Thanks in advance.
Manmohan.
04-30-2010 07:48 AM
Manmohan,
What does sh flash or sh flash all shows?
Reza
04-30-2010 07:52 AM
here is show flash all output
------------------ show flash: all ------------------
-#- --length-- -----date/time------ path
1 38220736 Mar 9 2008 09:25:08 +00:00 c2800nm-advipservicesk9-mz.124-12c.bin
25640960 bytes available (38223872 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
Number of Heads: 4
Number of Cylinders 978
Sectors per Cylinder 32
Sector Size 512
Total Sectors 125184
ATA CARD FORMAT
Number of FAT Sectors 62
Sectors Per Cluster 8
Number of Clusters 15592
Number of Data Sectors 125024
Base Root Sector 252
Base FAT Sector 128
Base Data Sector 284
ATA MONLIB INFO
Image Monlib size = 61240
Disk monlib size = 65536
Name = piptom-atafslib-m
Monlib Start sector = 2
Monlib End sector = 121
Monlib updated by = C2800NM-ADVIPSERVICESK9-M12.4(12a)
Monlib version = 1
------------------ dir nvram: ------------------
Directory of nvram:/
226 -rw- 12687
227 ---- 46
228 -rw- 12687
1 -rw- 0
2 ---- 13
245752 bytes total (230919 bytes free)
04-30-2010 08:04 AM
Hi Manmohan,
As per Reza we cannot see any kind of crash info file getting saved on the flash.
Can you check the logs and try to see if the crash info file was saved on flash.
You might see the output like "writing crashinfo on the flash"
Rahul
04-30-2010 08:10 AM
Can you check " sh ver" and see if you see a "Bus Error exception"?
Reza
04-30-2010 11:16 PM
If show version says system restarted due to bus error or software, etc..
It should be present in flash as crashinfo.
However if you are not able to find that, then simply run command
sh tech
Smitesh
