Webcast-Catalyst9k
Cisco 2821 router and 4 port esw
Can I use this wic into my cisco 2821?
Best regars
Re: Cisco 2821 router and 4 port esw
Friend,
If you are talking about HWIC-4ESW, then it is supported on the 2821..
Have a look at the data sheet for the supported modules
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8016fa68.html
HTH, rate if it does
Narayan
No...
I have 2 wics.. no hwic
1- 10BT ethernet
1- 4port esw
Can they run under 2821?
Can you tell me the product code of the modules?
Where is the code?
The part code would be written on the shhipment box. Check this against the data sheet provided earlier and see whether its supported or not
Narayan
I only have the hardware.. nothing more
168
