Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
cisco 2821 & wic 1enet
Hi, I ve a new 2821 and and old wic 1 enet?
Is compatible this wic with this router?
Best regards
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: cisco 2821 & wic 1enet
If you are connecting this 2821 router to 2 ethernet devices, the ethernet ports supplied by this router should be enough.
It wasn't supported under 2600 series so I highly doubt it's supported under the 2800 series.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
The cisco 2821 has 2 fastethernet ports,I need to connect one to the swicht and the other one to the lmds device.. is possible? or Ineed ti purchase a 1-lan HWIC or something like this?
the 2821 is wic orhwic empty.
I want to insert a wic 1adsl only.
http://www.cisco.com/en/US/products/ps5854/prod_models_comparison.html
The 2821 has 2 lan ports.. one will the used to the lan and the other one to the lmds ethernet port.
Its ok?
311
