Cisco 2851 ISR Router will not boot. Boots to ROMMON
My Cisco 2851 will no longer boot.  It only boots to ROMMON
I transfered the image over via xmodem booted the router formated the flash copied the image to flash and rebooted which did not seem to resolve the issue.  Any ideas?  is it the compact flash card or some other issue?
System Bootstrap, Version 12.4(13r)T6, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
Initializing memory for ECC
c2851 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
open(): Open Error = -66
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
loadprog: error - on file open
boot: cannot load "flash:c2800nm-adventerprisek9-mz.151-4.M7.bin"
rommon 1 >
Everyone's tags (1)
1 REPLY
VIP Purple
My first try would be to
My first try would be to format a new CF-Card (that router should at least accept 1GB cards) on the PC as FAT32 and put the image directly on that card. With that you eliminate also the XMODEM-transfer as a problem.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
56
