Community Member
Cisco 2851 ISR Router will not boot. Boots to ROMMON
System Bootstrap, Version 12.4(13r)T6, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
Initializing memory for ECC
c2851 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
open(): Open Error = -66
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
loadprog: error - on file open
boot: cannot load "flash:c2800nm-adventerprisek9-mz.151-4.M7.bin"
rommon 1 >
1 REPLY
Hi,     Can you verify flash
     Can you verify flash is opening up properly and displaying IOS you wish to boot in it.  Please use below command in romon to verify.
rommon 1 >dev                    ### Lists the available disk ###
rommon 1 >dir flash:            ####verify your file is getting displayed and it is not in form of directory
Finally u can attempt manual boot attempt after u verify your file is present.
rommon 1 >boot flash:/c2800nm-adventerprisek9-mz.151-4.M7.bin
Thanks and regards
Anilkumar Dantu
195
