I am working on a config to help with VOIP issues and some expansion for my company.
we have a COX Optical 25 meg fiber line coming in to their equpment.
its patched via Cat6 which is plugged in to a 8 port netgear gigabit switch
with 2 connections going in to a sonic wall 2400 ports X1 and X2
ports X0 is plugged in to the 192.168.100.0 network on 2 cisco switches for data
X4 is plugged in to 2 cisco switches with all the VOIP phones plugged in.
the vendor says having our VOIP phones going though the Sonic wall is bad so I want to configure the 2911 to handle voip side and leave the data going though the Sonic wall.
I would like to replace the 8 port swith that takes the COX feed and plug it in to GE0/0
and use GE0/1 for the Data to the sonic wall
and use GE0/2 to the cisco switch for the voip side
no wan cards in the router yet and the more I look at it I dont think its possible to eliminate the 8 port switch with out adding something to the 2911
I can upload a drawing to help
thank you
