ā01-04-2014 09:46 AM - edited ā03-07-2019 05:22 PM
Hello Experts
I am novice in the routers/networking domain, I need your valuable inputs in setting up our new Cisco 2911 router. As per the basic configuration guide I have attached the router with USB cable to one of my Windows 2008 server and installed Cisco_usbconsole_driver software and now I don't see the message of "Found New Hardware".
Now what are the next steps ? How will I activate the web based UI to access the router and do the basic configuration ?
Please advise. Thanks
Sri
ā01-07-2014 04:02 AM
Hello All
After restarting the router I could see some log in hyper terminal console and the final error is as below:
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 26-Feb-13 03:42 by prod_rel_team
*Jan 6 18:30:57.715: %SNMP-5-COLDSTART: SNMP agent on host yourname is undergoi
ng a cold start
*Jan 6 18:30:58.331: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jan 6 18:30:58.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-S
ervice-Engine0/0, changed state to down
*Jan 6 18:59:07.139: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pin
ged 10.10.10.4.
Can you please advice what is the issue here ?
Srikar
ā01-07-2014 07:45 AM
Your router is configured as a DHCP server and before offering an IP from its scopes it will ping the IP to see if it ain't already assigned on a host which seems to be the case here so it will not lease this IP and will try to offer the next free non duplicate IP in its scope.
Alain
