Webcast-Catalyst9k
Cisco 2924 Switch
I have a 2924 (copper only) and would like to config it to accept my connectivity through my DSL connection. How do I input the IP/gateway configs for acceptance?
I would also like to be able to have my collegues log on from the outside and run one of my programs from their location. How do I config a port(s)for them to access my program.
Thanks in advance....
Purple
Re: Cisco 2924 Switch
this is a layer 2 switch only and any addressing or gateway is strictly used to manage the switch . If you just want to use it for additonal ports just plug it into the DSL ethernet port , but that dsl modem would have to do NAT in order for it to work .
Can anybody recommend to me what kind piece of equipment could be used to complete my task?
You can buy a Cisco 800 series router for configuring it to the requirement. Please see the link below for more info on the product.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet09186a008010e5c5.html
HTH,
-amit singh
Thanks, I'll try this and put configs on, in you opinion are the configurations the same as switches (ie IP address/default gateway)?
396
