Cisco 2950G utilization 60% and above
hi,
cisco 2950G switch memory utilization observed 60% and above with init process taking more memory. Do we have cisco document to confirm whether it is normal behavior for cisco 2950.
Re: Cisco 2950G utilization 60% and above
hi,
CPU utilization value of 30 percent to 50 percent, even under minimal load is normal value in switch 2900xl and 3500xl,Check out teh belwo link for troubleshootinh high CPU value in 2900 series switches.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080094e78.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Hi Ganesh,
thanks,
I am looking for Mmemory utilization/threshold levesl for catalyst switches..!
Normally in idle condition below 50 % and if it has no load with
utilization more than 50 % there is some porblem,Check out the below link
for trouble shooting on switches for memory problem
http://www.ciscosystems.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080125913.shtml#high_memory
Hope to help !!
Ganesh.H
Hi Ganesh,
Init process taking 50% of the total memory which 8 Mb. Please confirm is it normal for 2950 and do we have any document..
------------------ show process memory ------------------
Total: 7777184, Used: 4424488, Free: 3352696
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0     132216       5044    3351984          0          0 *Init*
Hi Ganesh,
Can you post the show version and show memory output of the switch !!
Ganesh.H
------------------ show version ------------------
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA13, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by cisco Systems, Inc.
Compiled Fri 27-Feb-09 22:20 by amvarma
Image text-base: 0x80010000, data-base: 0x80570000
ROM: Bootstrap program is C2950 boot loader
Switch uptime is 7 day, 50 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA13.bin"
cisco WS-C2950G-48-EI (RC32300) processor (revision J0) with 20957K bytes of memory.
Processor board ID xxxx
Last reset from system-reset
Running Enhanced Image
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0C:30:69:18:80
Motherboard assembly number: 73-7409-12
Power supply part number: 34-0965-01
Motherboard serial number: xxxx
Power supply serial number: xxxx
Model revision number: J0
Motherboard revision number: A0
Model number: WS-C2950G-48-EI
System serial number: xxxx
Configuration register is 0xF
   0   0      12880     444816      12880          0          0 *Sched*
   0   0    8620756    4331132     205076     990680          0 *Dead*
   1   0          0          0       6808          0          0 Chunk Manager
   2   0        184        184       3808          0          0 Load Meter
   3   0      84812     276640       6808          0          0 SpanTree Helper
   4   0        184        184       6808          0          0 Next Page
   5   0          0          0       6808          0          0 Check heaps
   6   0      90212     195768      12180      47260     649804 Pool Manager
   7   0        184        184       6808          0          0 Timers
   8   0     365104     328568     148488          0      62384 Entity MIB API
   9   0          0          0       6808          0          0 HC Counter Timer
  10   0        136         92       6944          0          0 ARP Input
  11   0          0          0       6808          0          0 Net Input
  12   0          0          0       6808          0          0 Critical Bkgnd
  13   0      25504          0      13072       3360          0 Net Background
  14   0        320        184      12944          0          0 Logger
  15   0        184        184       6808          0          0 TTY Background
  16   0          0          0       9808          0          0 Per-Second Jobs
  17   0        184        184       6808          0          0 Compute load avg
  18   0       1484        912       6808        756          0 Per-minute Jobs
  19   0          0          0       6808          0          0 AggMgr Process
  20   0        320        184       3944          0          0 Calhoun Storm Co
  21   0          0          0       6808          0          0 Calhoun LED Proc
  22   0   18039292   18039292       3808          0          0 Calhoun Statisti
  23   0        184        184       6808          0          0 HMATM Learn proc
  24   0     630012      63708      32472          0          0 CalhounPM
  25   0        184        184       6808          0          0 Link Status Proc
  26   0          0          0       6808          0          0 CalhounInsIpopti
  27   0          0          0       3808          0          0 Calhoun DHCP Sno
  28   0     406928     400720      13016          0          0 CDP Protocol
  29   0          0          0       6808          0          0 DHCP Snooping
  30   0      11424       2328      15172          0          0 IP Input
  31   0      20748       1132      21560          0          0 DTP Protocol
  32   0        184        184       6808          0          0 Ethchnl
  33   0      65436      34912      24612       2340          0 VLAN Manager
  34   0        184        184       6808          0          0 PI MATM Aging Pr
  35   0          0     287004       6808          0          0 VMATM Callback
  36   0     573176      15376      15852      17680          0 Spanning Tree
  37   0        412        184       7036          0          0 UDLD
  38   0        152          0       6960          0          0 Port-Security
  39   0      30208       1144      22256          0          0 DHCPD Receive
  40   0          0          0       6828          0          0 HTTP Timer
  41   0          0          0       6808          0          0 RARP Input
  42   0          0       5820      12808          0          0 TCP Timer
  43   0     295856          0      12808          0          0 TCP Protocols
  44   0          0          0       6808          0          0 Socket Timers
  45   0       8140     144496      14948          0          0 L2MM
  46   0          0          0       6808          0          0 MRD
  47   0          0          0       6808          0          0 IGMPSN
  48   0          0          0       3808          0          0 IGMP Snooping Pr
  49   0          0          0       3808          0          0 IGMP Snooping Re
  50   0          0          0       3808          0          0 IP Multicast Dat
  51   0       2720        184       9344          0          0 L2TRACE SERVER
  52   0        184        184       6808          0          0 Cluster L2
  53   0          0          0       6808          0          0 Cluster RARP
  54   0     351044     350656       7196          0          0 Cluster Base
  56   0          0          0       6808          0          0 DHCPD Timer
  57   0          0         68       9808          0          0 Router Autoconf
  58   0          0          0       6808          0          0 Syslog Traps
  59   0        184        184       6808          0          0 VTPMIB EDIT BUFF
  60   0     230760     635592      11492          0          0 PM Callback
  61   0       7608       1808      14232          0          0 VTP Trap Process
  62   0        152          0       6960          0          0 DHCPD Database
  63   0        184        184       3808          0          0 Calhoun EnvMon P
  64   0        184        184       3808          0          0 STP STACK TOPOLO
  65   0        184        184       3808          0          0 STP FAST TRANSIT
  66   0        184        184       3808          0          0 STP STACK TOPOLO
  67   0        184        184       3808          0          0 CSRT RAPID TRANS
  68   1     750004     749104      13708          0          0 Virtual Exec
  70   0          0          0       6828          0          0 SNMP Timers
  71   0    5675104    4982576      67520     598528          0 IP SNMP
  72   0   34668520          0      12808          0          0 PDU DISPATCHER
  73   0   76738356  111406876      12808          0          0 SNMP ENGINE
  74   0          0          0      12808          0          0 SNMP ConfCopyPro
  75   0          0          0      12808          0          0 SNMP Traps
                                  4421288 Total
Any luck...
1025
