Webcast-Catalyst9k
cisco 2960 backup
I am currently backing up the startup configuration file on all our switches.
What files are needed to recover from a switch failure? That is if it needed to be replaced by a new switch.
jason
1 ACCEPTED SOLUTION
Re: cisco 2960 backup
I would backup the startup-config, vlan.dat file and the IOS image (depending on the replacement device)
1 REPLY
358
