Cisco 2960 hulc led process going high
Hi support,
I have below 2960 switch where hulc led process is taking 40 % of  CPU.
Please advise
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 02:13 by prod_rel_team
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(53r)SEY3, RELEASE SOFTWARE (fc1)
DXBPT01AC04 uptime is 24 weeks, 1 day, 12 hours, 22 minutes
System image file is "flash:/c2960-lanbasek9-mz.122-58.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-48PST-L (PowerPC405) processor (revision J0) with 65536K bytes of memory.
Processor board ID FCQ1624Y0UP
Last reset from power-on
Green
Hi,IOS ver 12.2.58 SE seems
IOS ver 12.2.58 SE seems to be a very buggy release train.
Mentioned a few times on the forum.
I strongly suggest that you regrade you switch to 12.2.55
The latest anf suggested release from cisco for you switch is:-
c2960-lanbasek9-mz.122-55.SE9.bin or TAR
Alex
Regards, Alex. Please rate useful posts.
The "Hulc LED" process does
The "Hulc LED" process does following tasks:
- Check Link status on every port
- If the switch supports POE, it checks to see if there is a Power Device (PD) detected
- Check the status of the transceiver
- Update Fan status
- Set Main LED and ports LEDs
- Update both Power Supplies and RPS
- Check on system temperature status
2)
Think of upgrading te IOS.
Inayath
*Plz dont forget to rate usefull posts.
183
