12-18-2013 02:20 AM - edited 03-07-2019 05:08 PM
The above is the port status of a problem port , we've connect and Access point to this port . It shows 25650input errors and 8559 CRC error, is it a cabling problem or the port is faulty , what does it means?
12-18-2013 05:38 AM
Hi Raymond,
Normally this points to layer 1 issues please check the following:
1. Check the speed/duplex both the ends
2. Check the cable / fiber / trasnceiver
3. Check by changing the speed and duplexto half or Auto
4. Chek if the grounding is proper
5. Check patch panel (if there is one)
Also this is a link for a cable test check it out:
https://supportforums.cisco.com/docs/DOC-18983
Hope this helps.
12-18-2013 06:04 AM
Post the output to the following commands:
1. sh intereface
2. sh controller eth
3. sh version
Sent from Cisco Technical Support Nintendo App
12-18-2013 07:07 AM
Check with cable and if possible run tdr on that port.
CRC is definitely a physical layer issue.
Whats the distance b/w these two endpoints.
Guru
