Cisco 2960 problem
I've got these 2960s and I'm trying to upgrade the code, I copy tftp the image but when I try to set the boot statement I get the following error and as a result switch never boots with the new image:
Switch(config)#boot system flash:c2960-lanbasek9-mz.122-40.SE.bin
vb:: Read-only file system
My confi-register is set to 0xF and looks like you can't set the config-register value from the config mode.
Re: Cisco 2960 problem
I highly recommend you use the archive command to upgrade Catalyst stackable switches.
You will find everything you need to know in this doc:
http://www.cisco.com/en/US/products/ps6406/products_configuration_guide_chapter09186a00808752d2.html
Good luck!
NS
Try this:
You need to boot to rommon by holding the mode button on the switch while power cycling it.
Run these commands:
flash_init
set_bs vb: rw
boot
After you have booted, add the appropriate variables and you should be all set.
wr mem and reload to test, it should boot fine
580
