Webcast-Catalyst9k
cisco 2960-S crashed IOS
Dear all
my cisco ios 2960S is crashed and the ios is gone
the issue is i am connecting my pc to managment port
and i give
switch: IP_ADDR x.x.x.x/255.255.255.0
and also
switch:DEFAULT-ROUTER
but i can not copy tftp to flash!!
according that i have L3 port (managment) why should i use xmodem?
please help
VIP Super Bronze
When you connect your PC to the management port, does the management port on the switch go to up and up mode?
Can you ping the PC from the switch?
Can you ping the switch from the PC?
What model 2960 do you have?
Dear Reza
when i am connecting my pc to managment port
i can not ping from pc the managment port but i can ping from managment port the pc!
this is done after i added some SET command to the switch
like switch:SET IP_ADDR x.x.x.x/x.x.x.x
and so on
but the problem is when i want to copy something from tftp: to flash: its not possible
by teh way the switch model is 2960-S
i think that we do not need use xmodem to copy the ios because this model has a layer 3 managment port
and it can ping my pc!
thanks
Can you show us the commmand you use for copying from TFTP ?
508
