Cisco 2960 Spec
                   I have been looking for below spec related to cisco Catalyst 2960S-48FPS-L, any help will be appreciated;
802.1X Clients:
LLDP Neighbors:
ARP Entries:
IP Interfaces:
IPv4 Routes:
OSPF Instances:
OSPF Adjacencies:
ECMP Paths:
VRRP Instances:
Hall of Fame Super Gold
Cisco 2960 Spec
Exactly, what are you trying to achieve?
Re: Cisco 2960 Spec
Was doing comparison with similar Avaya switches.
Re: Cisco 2960 Spec
Hi Nimesh,
Kindly find below the Data Sheet link for Cisco 2960 device. You can refer to the details available here & perform the comparison.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12200/data_sheet_c78-726680.html
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
Re: Cisco 2960 Spec
Thank you but it does not have info that I am looking for.
Re: Cisco 2960 Spec
OSPF Instances:
OSPF Adjacencies:
Straight up, the 2960S can't do dynamic routing, only 16 static routes are allowed.
2960-XR can do limited OSPF routing.
202
