Webcast-Catalyst9k
Cisco 2960 SW trunk with Huawei
Hi everybody,
Cisco 2960 SW gigabit ethernet 0/1 interface connected with Huawei 2309 SW from gigabit ethernet 0/0/1 interface . But trunk interface not working. And I configured Huawei and Cisco for voice, ip phone. but not working. Can you help me?
Cisco 2960
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
ip http server
ip http secure-server
control-plane
line con 0
login local
line vty 0 4
login local
line vty 5 15
login
end
HUAWEİ S2700-26TP-EI-DC
vlan batch 203 600
cluster enable
ntdp enable
ntdp hop 16
ndp enable
bpdu enable
dhcp enable
undo http server enable
drop illegal-mac alarm
vlan 203
description INTERNET
vlan 600
description VOICE
interface Vlanif1
ip address dhcp-alloc
interface Ethernet0/0/1
port link-type trunk
port trunk allow-pass vlan 2 to 4094
ntdp enable
ndp enable
interface Ethernet0/0/2
voice-vlan 600 enable
port hybrid untagged vlan 203
ntdp enable
ndp enable
interface Ethernet0/0/3
ntdp enable
ndp enable
interface Ethernet0/0/4
ntdp enable
ndp enable
interface Ethernet0/0/5
ntdp enable
ndp enable
interface GigabitEthernet0/0/1
ntdp enable
ndp enable
interface NULL0
snmp-agent
snmp-agent local-engineid 000007DB7F00000100002DC7
snmp-agent sys-info version v3
user-interface con 0
idle-timeout 0 0
user-interface vty 0 4
return
1 REPLY
Gold
Re: Cisco 2960 SW trunk with Huawei
Hi Dong,
Not sure if this is due to speed and duplex problem, is your interfaces showing as up on both sides?
I would try below configuration.
Cisco
speed 1000
duplex full
HUAWEİ
port trunk permit vlan all
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
835
