Cisco 2960 Switch - SFP
Hi2All
I am wondering if two SFP ports on my Cisco 2960 can be combined as one pipe connection to my backbone switch 4506
This is redundancy and additional 1GB pipe, in total my backbone connection from this switch would be 2GB
cheers
Anthony
Re: Cisco 2960 Switch - SFP
You can certainly do that. You need to configure EtherChannel between the
devices.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080
094646.shtml#topic6
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/1
2.2_25_see/configuration/guide/swethchl.html
Hope this helps.
NT
Hi2All,
Thanks for answering.
Are these config ok for etherchannel
On 2960 Switch & Backbone_switch 4506 I configure these.
interface range giga 0/1 - 2
switchport mode trunk
channel-group 1 mode active
Any precautions do I need for Ethernchannel during configuration.
cheers
Anthony
That configuration looks good. As long as both links are active, you should
not have any problem.
NT
Hi2All,
which command would help to understand the current bandwidth usuage of uplink on BackBone_Switch and how do I check the same from Cisco 2960 switch.
Just a thought ::::::      Can i do etherchannel with ethernet giga0/1 + sfp giga 0/1 on cisco 2960 with backbone 4509 two giga ethernet interface
cheers
Anthony
1165
