10-06-2014 07:52 AM - edited 03-07-2019 09:00 PM
I am trying to connect fibre into interface g 1/0/49 sfp module and the activity light is on, stable and green but there is no activity. Any suggestions as to how to gain connectivity?
Solved! Go to Solution.
10-06-2014 02:45 PM
Post the following command outputs:
1. sh run interface Gi1/0/49;
2. sh interface Gi1/0/49 status;
3. sh interface Gi1/0/49; and
4. sh interface Gi1/0/49 trunk
10-06-2014 02:45 PM
10-07-2014 11:20 AM
sh run int gi 1/0/49
Building configuration...
Current configuration : 121 bytes
interface GigabitEthernet1/0/49
switchport mode access
switchport nonegotiate
speed nonegotiate
no cdp enable
end
sh int gi 1/0/49
GigabitEthernet1/0/49 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is c025.5c0c.1431 (bia c025.5c0c.1431)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is force-up, media type is 1000BaseLX SFP
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
sh int gi 1/0/49 status
Port Name Status Vlan Duplex Speed Type
Gi1/0/49 notconnect 1 auto auto 1000BaseLX SF
P
sh int gi 1/0/49 trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/49 off 802.1q other 1
Port Vlans allowed on trunk
Gi1/0/49 none
Port Vlans allowed and active in management domain
Gi1/0/49 none
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/49 none
10-07-2014 12:52 PM
sh int gi 1/0/49
GigabitEthernet1/0/49 is down, line protocol is down (notconnect) >.. Which means either the cable or port is faulty.
Kindly check again with the correct cable and try to swap the SFP if cable is fine.(you can also do the testing by connecting back to back SFP ports).
10-07-2014 02:10 PM
I agree. This means Layer 1 is down. This could mean SFP could be faulty, cable could be faulty, etc.
interface GigabitEthernet1/0/49 switchport mode access switchport nonegotiate speed nonegotiate
These commands don't make sense.
You've got a GLC-LH-SM(D) installed and you've enabled "speed nonegotiate"? Take this out.
Next, you've got "switchport nonegotiate" and you've got "switchport mode access"? You've literally disabled DTP and specified that the link is-and-will-be an access port. What is the configuration on the other end?
10-08-2014 06:21 AM
Current configuration : 4536 bytes
! Last configuration change at 08:42:06 UTC Fri Oct 3 2014
! NVRAM config last updated at 09:05:00 UTC Mon Aug 25 2014 by cisco
version 12.2
no service pad
boot-start-marker
boot-end-marker
enable secret 5 $1$zBsc$BV3S1zlFSWusjdU2PVkdX/
no aaa new-model
clock timezone UTC -4
switch 1 provision ws-c3750g-12s
switch 2 provision ws-c3750g-12s
system mtu routing 1500
ip subnet-zero
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
errdisable recovery cause gbic-invalid
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
speed nonegotiate
no cdp enable
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
