Cisco 3130 G
dukeminus
Here is my configuration. Why is it showing SD
interface Port-channel1
switchport access vlan 21
switchport mode access
switchport nonegotiate
no logging event link-status
no snmp trap link-status
spanning-tree portfast
interface GigabitEthernet1/0/9
channel-group 1 mode active
interface GigabitEthernet2/0/1
1     Po1 (SD)     LACP       Gi1/0/9(I)   Gi2/0/1(I)
19 Replies 19
Reza Sharifi
Is the other side of the portchannel configured?
Yes.  It is a LinuX server with 4 ports bonded
Can you post the folowing?
sh ip int bri gi2/0/1
sh ip int bri gi1/0/9
sh int po1
sh run int po1
sh etherc 1 summ
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet2/0/1   unassigned      YES unset  up                    up
GigabitEthernet1/0/9   unassigned      YES unset  up                    up
Port-channel1 is down, line protocol is down (notconnect)
  Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
  Description: rdlab7
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Last input never, output 19w2d, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     3519 packets input, 645764 bytes, 0 no buffer
     Received 1837 broadcasts (617 multicasts)
     0 watchdog, 617 multicast, 0 pause input
     30757 packets output, 2733918 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
Current configuration : 238 bytes
description rdlab7
spanning-tree bpduguard enable
end
sh etherc 1 summ
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 5
Number of aggregators:           5
Group  Port-channel  Protocol    Ports
1      Po1(SD)         LACP      Gi1/0/9(I)  Gi2/0/1(I)
Sandeep Choudhary
HI Dukeminus,
Try this command :
The opposite side of the LACP EtherChannel will typically be configured as passive, however it can be active as well.
channel-group 1 mode passive
Interface Gigabitethernet 1/0/9
interface Gigabitethernet 2/0/1
instead of  channel-group 1 mode active on both the switch interafce.
and then see the output of show etherchannel summary
and then wait for 2-3 minutes to see the port channel up.
Please rate if it helps.
still show same
If still it is not working then can you please try another port channel (5 or 6 or other then 1) and then apply this port channnel to both switch port.
thn show the status.
still having same problem:
7      Po7(SD)         LACP      Gi1/0/9(I)  Gi2/0/1(I)
ok can u paste output :
sh int gig2/0/1
sh int gig1/0/9
sh int po7
let see whats the error is?
Reagards
#sh int gig2/0/1
GigabitEthernet2/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 68bd.abd0.f281 (bia 68bd.abd0.f281)
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseX
  Last input never, output 00:00:37, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 43
     438963087 packets input, 169783348217 bytes, 0 no buffer
     Received 30420 broadcasts (755 multicasts)
     0 watchdog, 755 multicast, 361619089 pause input
     512468790 packets output, 228054130481 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
#sh int gig1/0/9
GigabitEthernet1/0/9 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 68bd.abd0.ea09 (bia 68bd.abd0.ea09)
  Last input never, output 00:00:00, output hang never
  5 minute output rate 1000 bits/sec, 1 packets/sec
     526 packets input, 101428 bytes, 0 no buffer
     Received 385 broadcasts (307 multicasts)
     0 watchdog, 307 multicast, 0 pause input
     59661912 packets output, 4627452589 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
sh int po7
Port-channel7 is down, line protocol is down (notconnect)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
The ports are not being added to the portchannel.
Gi1/0/9(I)  Gi2/0/1(I) I is stand-alone
Gi1/0/9(I)  Gi2/0/1(P) P is for bundled
What version of IOS are you running?
sh ver
Cisco IOS Software, CBS31X0 Software (CBS31X0-UNIVERSALK9-M), Version 12.2(53)SE1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 12-Mar-10 16:32 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
HI Duke,
Port Channel this is a PO group to an ESX server?
In which case you will need different channel commands:
"channel-group 28 mode on"
By specfiying active in the channel-group commands your effectively turning LACP negotiation on then expecting ESX to respond  to this and form an LACP based channel.
Unfortuantely up until ESX / ESXi 5.x LACP isn't supported and no negotiation will happen.
However Static Trunking / EtherChannel is supported (IP Hash load-balancing in ESX) in combination with "mode on" static etherchannel.
Basically when you configured a channel-group with the "mode on" command you explictly force trunking without any channel-protocol negotation (PAgP or LACP).
Any questions let me know.
Have u did no shutdown to the port channel????
