08-31-2012 07:46 AM - edited 03-07-2019 08:38 AM
Here is my configuration. Why is it showing SD
interface Port-channel1
switchport access vlan 21
switchport mode access
switchport nonegotiate
no logging event link-status
no snmp trap link-status
spanning-tree portfast
interface GigabitEthernet1/0/9
channel-group 1 mode active
interface GigabitEthernet2/0/1
1 Po1 (SD) LACP Gi1/0/9(I) Gi2/0/1(I)
08-31-2012 08:49 AM
Is the other side of the portchannel configured?
08-31-2012 08:57 AM
Yes. It is a LinuX server with 4 ports bonded
08-31-2012 09:01 AM
Can you post the folowing?
sh ip int bri gi2/0/1
sh ip int bri gi1/0/9
sh int po1
sh run int po1
sh etherc 1 summ
08-31-2012 09:12 AM
GigabitEthernet2/0/1 unassigned YES unset up up
GigabitEthernet1/0/9 unassigned YES unset up up
Port-channel1 is down, line protocol is down (notconnect)
Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
Description: rdlab7
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Last input never, output 19w2d, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
3519 packets input, 645764 bytes, 0 no buffer
Received 1837 broadcasts (617 multicasts)
0 watchdog, 617 multicast, 0 pause input
30757 packets output, 2733918 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Current configuration : 238 bytes
description rdlab7
spanning-tree bpduguard enable
end
sh etherc 1 summ
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 5
Number of aggregators: 5
Group Port-channel Protocol Ports
1 Po1(SD) LACP Gi1/0/9(I) Gi2/0/1(I)
08-31-2012 09:05 AM
HI Dukeminus,
Try this command :
The opposite side of the LACP EtherChannel will typically be configured as passive, however it can be active as well.
channel-group 1 mode passive
Interface Gigabitethernet 1/0/9
interface Gigabitethernet 2/0/1
instead of channel-group 1 mode active on both the switch interafce.
and then see the output of show etherchannel summary
and then wait for 2-3 minutes to see the port channel up.
Please rate if it helps.
08-31-2012 09:16 AM
still show same
08-31-2012 09:22 AM
If still it is not working then can you please try another port channel (5 or 6 or other then 1) and then apply this port channnel to both switch port.
thn show the status.
08-31-2012 09:47 AM
still having same problem:
7 Po7(SD) LACP Gi1/0/9(I) Gi2/0/1(I)
08-31-2012 09:48 AM
ok can u paste output :
sh int gig2/0/1
sh int gig1/0/9
sh int po7
let see whats the error is?
Reagards
08-31-2012 09:58 AM
#sh int gig2/0/1
GigabitEthernet2/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 68bd.abd0.f281 (bia 68bd.abd0.f281)
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseX
Last input never, output 00:00:37, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 43
438963087 packets input, 169783348217 bytes, 0 no buffer
Received 30420 broadcasts (755 multicasts)
0 watchdog, 755 multicast, 361619089 pause input
512468790 packets output, 228054130481 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
#sh int gig1/0/9
GigabitEthernet1/0/9 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 68bd.abd0.ea09 (bia 68bd.abd0.ea09)
Last input never, output 00:00:00, output hang never
5 minute output rate 1000 bits/sec, 1 packets/sec
526 packets input, 101428 bytes, 0 no buffer
Received 385 broadcasts (307 multicasts)
0 watchdog, 307 multicast, 0 pause input
59661912 packets output, 4627452589 bytes, 0 underruns
0 output errors, 0 collisions, 7 interface resets
sh int po7
Port-channel7 is down, line protocol is down (notconnect)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
08-31-2012 09:47 AM
The ports are not being added to the portchannel.
Gi1/0/9(I) Gi2/0/1(I) I is stand-alone
Gi1/0/9(I) Gi2/0/1(P) P is for bundled
What version of IOS are you running?
08-31-2012 09:52 AM
sh ver
Cisco IOS Software, CBS31X0 Software (CBS31X0-UNIVERSALK9-M), Version 12.2(53)SE1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 12-Mar-10 16:32 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
08-31-2012 09:57 AM
HI Duke,
Port Channel this is a PO group to an ESX server?
In which case you will need different channel commands:
"channel-group 28 mode on"
By specfiying active in the channel-group commands your effectively turning LACP negotiation on then expecting ESX to respond to this and form an LACP based channel.
Unfortuantely up until ESX / ESXi 5.x LACP isn't supported and no negotiation will happen.
However Static Trunking / EtherChannel is supported (IP Hash load-balancing in ESX) in combination with "mode on" static etherchannel.
Basically when you configured a channel-group with the "mode on" command you explictly force trunking without any channel-protocol negotation (PAgP or LACP).
Any questions let me know.
08-31-2012 10:02 AM
Have u did no shutdown to the port channel????
