Cisco 3524 PWR XL - Port Security
Does anyone know if Cisco 3524 switch support port-security? There's no port-security option under the current IOS (3500XL-c3h2-mz-120.5.2-XU.bin).
cv_sw(config-if)#switchport ?
access Set access mode characteristics of the interface
mode Set trunking mode of the interface
multi Set characteristics when in multi-VLAN mode
priority Set 802.1p priorities
trunk Set trunking characteristics of the interface
voice Voice appliance attributes
I am unable to find a compatible matrix that would tell me if it does support port-security. If anyone can point me to the right direction, your input is greatly appreciated.
TIA,
hieu
1 ACCEPTED SOLUTION
Re: Cisco 3524 PWR XL - Port Security
You are using the wrong command. Go into the interface configuration mode and try the command below:
(config-if)#port ?
There will be a lot of options.
Reference: http://www.cisco.com/en/US/products/hw/switches/ps637/products_configuration_guide_chapter09186a008007e838.html#xtocid18
(config-if)#port ?
Danny -
Got it! Thanks for your response.
hieu
420
