Cisco 3550 48 Port SMI
Hi guys.
I am very new to the world of Cisco CLI but not networking in general and have been in networking for many years and i am a Network Administrator. Anyway I have a switch in work that i am now playing with and going to use to learn off.
So i have a Cisco 3550 48 Port SMI switch and i have run the following command to set it back to defaults
write erase
I now need to set the routers IP Address , SubNet Mask , Default gateway so that it can been seen on my LAN.
I have been hunting around trying to find the command but no joy. I do remember doing this a couple of years ago and it was something like set ip or ip address 10.10.1.1
Can anyone help me with the commands.
Many thanks
Craig
Re: Cisco 3550 48 Port SMI
Hi Craig
By default all of your interfaces will be in vlan 1, so easiest thing for you to do would be the following.
conf t
int vlan 1
ip address 10.10.1.1 255.255.255.0 (Assuming you are running with a /24 subnet)
no shut
end
If you are planning to telnet to the switch once you have configured it with an IP, then you will need to do the following.
conf t
username craig password
enable secret
line vty 0 4
login local
line vty 5 15
login local
end
I would recommend you not using vlan 1 for security reasons, but this will get you up and running and allow you to get onto the switch remotely to configure it.
Hope this helps
Martin
Purple
You can make the subnet any vlan you want . First create the layer 2 vlan .
conf t
ip routing
vlan 3,enter
exit
interface vlan 3
ip address 192.168.3.1 255.255.255.0
no shut
exit
interface range f0/1 - 48
switchport access vlan 3
Gold
to set the default gateway (if routing is not enabled and in use):
ip default-gateway x.x.x.x
173
