cisco 3550 vlans
I'm trying to configure two vlans that will contain two separate subnets. I don't want the subnet to see each other.
Does the configuration below will do the job?
Any comments...
int range f0/1 - 12
description Administrative
switchport access vlan 200
switchport mode access
int range f0/13 - 24
description Academic
switchport access vlan 100
interface GigabitEthernet0/1
description Trunk to Cisco6509 router
switchport mode trunk
interface GigabitEthernet0/2
switchport mode dynamic desirable
no shut
interface Vlan1
ip address 172.31.181.130 255.255.255.192
no shut
interface Vlan200
no ip address
no ip route-cache
no shut
interface Vlan100
no ip address
no ip route-cache
no shut
Re: cisco 3550 vlans
Even if u didnt not create the svi's it will work fine.
Mahmood
Would you not just want to carry the layer 2 vlans up to your 6509 and define the routers (svi) on the 6509? i.e. put interface vlan 100 and vlan 200 on the 6509? An ACL can be applied to prevent the subnets from "seeing" each other.
273
