Cisco 3560 and Tsunami Wifi Devices
Everyone, here is my issue. I have two buildings that we are trying to connect via two Tusnami Wifi devices. In my testing I am having troubles getting the two devices to transmit data or I should say that they see each other but no data is passed to my switches. I have attached a simple PDF so show my test enviroment. Basically I have a 3560 switch and a base tx/rx unit and another 3560 switch and satellite tx/rx unit. The two wifi devices will see each other an perform a link test between the two with great signal. From each side I can ping the IP I manually put on each wifi from my laptop, but cannot ping the other switch from either side. I have the devices attached to trunk ports on each switch. Has anyone had any experience with these devices. Thanks in advance.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cisco 3560 and Tsunami Wifi Devices
Hello Ronald,
start to verify the native vlan settings on both sides
sh int fasx/y switchport
the device data sheet declares they are able to carry vlan tagged frames (802.1Q)
see
http://www.proxim.com/downloads/products/mp16/DS_0806_MP16_3500_A4HR.pdf
a problem with native vlan mismatch could cause ip connectivity issues
Hope to help
Giuseppe
1 REPLY
Hello Ronald,
see
Hope to help
Giuseppe
503
