03-09-2014 06:47 AM - edited 03-07-2019 06:36 PM
Good Day guys ,
i've purchased some of the new 3560 cg catalyst switches. Am looking for some guidance/assistance into the procedure to change the default (vlan 1) to my management vlan (x). I have been successful in the addition of all my vlans inclusive of the management to the switch using the following command "switchport access vlan x" via the command line.
Currently I have CE 500's in my environment which allows you to change the management vlan from the GUI. Any recommendations/ assistance as to how this is now done on the newer model switches via command line or GUI would be greatly appreciated.
Christian.
Solved! Go to Solution.
03-09-2014 04:32 PM
conf t
vlan <BLAH>
name Management
exit
default interface vlan 1
interface vlan 1
shutdown
interface vlan <BLAH>
description YIPEE
ip address 1.2.3.4 255.255.255.0
no shutdown
03-09-2014 04:32 PM
conf t
vlan <BLAH>
name Management
exit
interface vlan 1
shutdown
description YIPEE
no shutdown
03-09-2014 06:39 PM
Thanks alot buddy! just got through.
Cheers!
03-10-2014 02:04 AM
Thank you very much for taking the time to rate our posts. :)
