Cisco 3560X 15.01 Universallk9
I cannot get a route map configured on my new Cisco 3560X. When I go into the vlan to apply the routemap the configuration
will not accept the ip policcy command.
Green
Look at this link to the config guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_1_se/configuration/guide/swiprout.html#wp1228588
Check you have followed the guidelines for PBR
To use PBR, you must first enable the routing template by using the
sdm prefer routing
global configuration command. PBR is not supported with the VLAN or default template. For more information on the SDM templates, see
Chapter 8 "Configuring SDM Templates."
Alex
Regards, Alex. Please rate useful posts.
VIP Super Bronze
557
