Cisco 3620 + Ethernet 4E - DHCP Only working on one interface!
Hi Guys, I just got an Ethernet 4E card for my 3620 and only 1 Interface at a time seems to be grabbing an IP Address from DHCP
All 4 interfaces are set to DHCP and no shut.
"Cisco3620#sh ip int brief
Ethernet0/0 unassigned YES DHCP up up
Ethernet0/1 10.30.0.1 YES NVRAM up up
Ethernet0/2 10.29.0.15 YES DHCP up up
Ethernet0/3 unassigned YES DHCP up up
BRI1/0 unassigned YES NVRAM administratively down down
Ethernet1/0 unassigned YES DHCP up up
Serial1/0 unassigned YES NVRAM administratively down down
BRI1/0:1 unassigned YES unset administratively down down
BRI1/0:2 unassigned YES unset administratively down down
Tunnel0 192.168.6.2 YES NVRAM up down
Tunnel1 192.168.15.2 YES NVRAM up down"
Below is my config:
Cisco3620#sh run
Building configuration...
Current configuration : 1510 bytes
version 12.3
service password-encryption
hostname Cisco3620
boot-start-marker
boot-end-marker
enable password 7 ####
no aaa new-model
ip subnet-zero
ip cef
ip dhcp pool Wireless(Eth1)
network 10.30.0.0 255.255.255.248
default-router 10.30.0.1
domain-name w1.ap1.noe.home
lease infinite
interface Ethernet0/0
description LAN
ip address dhcp
half-duplex
interface Ethernet0/1
ip address 10.30.0.1 255.255.255.248
half-duplex
interface Ethernet0/2
ip address dhcp
half-duplex
interface Ethernet0/3
ip address dhcp
half-duplex
interface BRI1/0
no ip address
encapsulation hdlc
shutdown
interface Ethernet1/0
ip address dhcp
half-duplex
interface Serial1/0
no ip address
shutdown
ip http server
ip classless
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password 7 ###
login
end
Running IOS: c3620-ix-mz.123-17a.bin
Any idea's?
Cheers, Mike.
Re: Cisco 3620 + Ethernet 4E - DHCP Only working on one interfac
Hi Mike,
Please provide info about how you are connected to the DHCP server with the Ethernet cards not succeding with getting an IP address.
General problems with DHCP may include the following:
1. Failure to configure a DHCP relay agent if the client is not directly connected to a DHCP server
2. No backward route in the routing table from the DHCP server to the subnet where the DHCP request came from.
3. Failure to configure excluded addresses in the DHCP server for addresses that are already assigned manually to default gateways or other hosts.
The DHCP server of course tries to assign an IP address from your range defined in the "network" command under the "dhcp-config" prompt, generally the first usable one in the specified subnet. If this IP address is already assigned manually on the subnet, ensure that this address is excluded from the DHCP pool with the "ip dhcp excluded-address" global config command.
Please verify these and inform me about your success.
Best regards:
Istvan
Hall of Fame Super Bronze
You are connecting the other LAN interfaces on different Vlans? If so, do you have a ip helper-address on the gateway from that Vlan so dhcp request can be forwarded to the server ?
If they are on the same Vlan, that design won't work. They need to be on separate Vlans.
Also, provide the model of the 4Port Module.
__
Edison.
Purple
Please explain what you are trying to do . Are you thinking the actual interfaces on the router are going to pull an address ??? I only see one dhcp pool of 7 addresses defined . Probably devices on E0/1 are working correct ?
Glen, I was thinking about the same thing. The IP address he wants aren't being generated by the router's DHCP. If you noticed E0/2, the subnet is not on the pool therefore I assume it was generated by a separated DHCP server.
Very odd config, I must say.
__
Edison.
Hi Edison,
I interpret this config the same way.
He wants to get the IP addresses from a different DHCP server.
At the same time this router acts as the DHCP server for the wireless clients.
Istvan
886
