cisco-3620 reloads unexpectedly
Hi Cisco
We have 2 routers that keeps reloading at the same time with similar error. We haven't had any change on both routers. I tried to find what
Both of them get similar error:
System returned to ROM by bus error at PC 0x612CC298
SDZC010100 uptime is 48 minutes
System returned to ROM by bus error at PC 0x612CC298, address 0x472C7FB4 at 21:19:42 edt Mon Aug 20 2007
System restarted at 21:21:50 edt Mon Aug 20 2007
System image file is "flash:c3620-ik9s-mz.122-7c.bin"
cisco 3620 (R4700) processor (revision 0x81) with 61440K/4096K bytes of memory.
Processor board ID 24808943
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 Virtual Private Network (VPN) Module(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
SDZC010100#
SDZC010200#show version
IOS (tm) 3600 Software (C3620-IK9S-M), Version 12.2(7c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 11-May-02 16:47 by pwade
Image text-base: 0x600089A8, data-base: 0x61314000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
SDZC010200 uptime is 58 minutes
System returned to ROM by bus error at PC 0x612CC298, address 0x4644DDD4 at 21:19:26 edt Mon Aug 20 2007
System restarted at 21:21:38 edt Mon Aug 20 2007
System image file is "slot0:c3620-ik9s-mz.122-7c.bin"
cisco 3620 (R4700) processor (revision 0x81) with 45056K/4096K bytes of memory.
Processor board ID 22865905
Bridging software.
8192K bytes of processor board System flash (Read/Write)
16384K bytes of processor board PCMCIA Slot0 flash (Read/Write)
1 ACCEPTED SOLUTION
Re: cisco-3620 reloads unexpectedly
there is a bug in the IOS (i believe the IOS before 12.2.15, but not sure). Upgrading the IOS should solve this problem. I had the same problem with a 3660.
Kind regards
Kind regards
121
