CIsco 3640 older model & nm-2fe2w-v1
jfinley
I have a customer who just purchased a nm-2fe2w and cannot get the module recognized. They are running 12.0.28d which by the software/hardware matrix should be recognized. Any idea why this is not the case?
A show diag displays:
IOS (tm) 3600 Software (C3640-IS-M), Version 12.0(28d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 19-Aug-05 19:00 by pwade
Image text-base: 0x60008918, data-base: 0x609AA000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Slot 2:
Unknown (type 216) port adapter, 0 ports
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
sachinraja
Level 9
Level 9
Pls find attached the datasheet of the NM-2FE-2W module.. and the specifications of the module..
http://cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a00801aa71c.html
Can you confirm the card type please? 3640 supports V2 and NM-2FE-2W cards... was this a working module or you are trying it for the first time??
Raj
adrian.chadd
Hm!
Minimum IOS in for support of that module for the 3640 is 12.0(7)XK -
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b1155.shtml
The release notes specify that the XK release features were merged into 12.1(2)T:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5014/products_tech_note09186a0080143d4e.shtml
It might not be supported in that particular 12.0 train. You may need to update to at least 12.1T or 12.2T?
glen.grant
You are running 12.0 mainline , it is not supported in that . It says it is supported with 12.1 T train version which means you have to run at least the minimum 12.1 T version recomended or it would be included in a 12.2 mainline version . Any 12.2 mainline should support that module .
