cisco 3750 booting problem
maninthemirrow
hello friends
l  was upgrading my cisco 3750 switch and by mistake press the yes button when reloading.l have also deleted the flash image to make more room before the upgrade and now it cannot boot again. this is all l see below
AS-Salis#2
[Resuming connection 2 to mls1 ... ]
øþøþøþøþøþøþøþøþøþøüøþøÿøþøþøþøþøþøþøüøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþøþ
l try using the console directly but it produce the same thing. any help out there please
thanks in advance
salis
Please try to issue "flash_init" before, then try again, if that would not fix it up, try with a smaller ios image.
Aref
9 Replies 9
hell Aref,
l went through the proceeding but it get stuck at the end as below:
Base ethernet MAC Address: 00:0d:29:48:a7:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    load_helper
    boot
switch: flash_init
Initializing Flash...
flashfs[0]: 4 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5632
flashfs[0]: Bytes available: 15993344
flashfs[0]: flashfs fsck took 7 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
Setting console baud rate to 115200...
 l get the scramble line when l press enter after waiting .
                                      ÿXüXøXüøþxüXøøþXøøüXüXøXøøüøüXüøüøüøüXüþþX
 when it get to the bottom setting console baud rate to 115200.. it stays there forever.
l try to delete the setting but false.
thanks
Try to set the baud rate to 9600.
Aref
I try to set the band but none of the commas allows it now.please which command will l use . Thanks you l have appreciate all your time and replay
Did you reload the switch after changing the baud rate?, if not, please try to reload it and see if it works.
hello Aref
l try boot and did not work and the message was not recognise but l follow the step till the image l load. l get  " transfer cancelled by remote system "
Aref
maninthemirrow
hello Aref
l have try with small image and it work then l did my upgrade after. now it is fully functional. thanks
Glad to know that and you are very welcome.
Aref
