10-08-2013 09:30 AM - edited 03-07-2019 03:54 PM
We have a cisco WS-C3750X-24 that sometimes shows high cpu.
Please see details below. When cpu was running high, we noticed
2 process that seems to be the culprit. One is VMATM Callback and one is IP Input.
What is VMATM? Can't seem to find much documentation with it.
Also, IP Input seems to be well documented but I'm wondering how it ties into VMATM if it does?
CPU utilization for five seconds: 99%/29%; one minute: 99%; five minutes: 90%
CPU utilization for five seconds: 73%/28%; one minute: 76%; five minutes: 77%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
237 49 53 924 0.00% 0.00% 0.00% 0 VMATM Callback<----------normal usage
237 119304 3710 32157 31.74% 27.42% 17.27% 0 VMATM Callback
198 541972 1524333 355 1.11% 0.55% 0.41% 0 IP Input <------------------normal usage
198 21565303 54238166 397 25.30% 25.51% 25.52% 0 IP Input
Version:
c3750e-universalk9npe-mz.122-55.SE3.bin
CSCtj95182 - High CPU on 3750 when network scanner is run
CSCtf23298 - tacacs-server host ' ' single-connection causes high CPU utilization
Solved! Go to Solution.
10-08-2013 10:50 AM
- This 'VMATM' process mainly takes care of the removing the addresses learnt on an interface when the interface goes down.
There are couple of things to be check on this kindly open a TAC case with cisco so that we provide you in depth analysis on the same
10-08-2013 11:59 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Besides or in addition to opening a TAC case, you might consider upgrading your IOS to 55SE7 or 55SE8. You might also double check none of your TCAM resources are being exceeding (i.e. not using the optimal SDM template).
10-08-2013 02:50 PM
I guess you recommend c3750e-universalk9-mz.122-58.SE2.bin and why?
Because 12.2(55)SE7 or SE8 are, by far, THE MOST STABLE IOS I've used. A lot of people also has seem to observe a significant improvement when they've upgraded or downgraded to this version.
10-08-2013 10:50 AM
10-08-2013 11:59 AM
Disclaimer
Posting
10-08-2013 12:26 PM
What would be the latest IOS for c3750e-universalk9npe-mz.122-55.SE3.bin?
I found this (c3750e-universalk9-mz.122-58.SE2.bin) but it doesn't have the npe designation.
10-08-2013 12:38 PM
I think I found it. I'm downloading
c3750e-universalk9npe-mz.122-58.SE2.bin now.
10-08-2013 02:23 PM
Don't. Just please DO NOT use this version.
For a 3750, use 12.2(55)SE8.
10-08-2013 02:38 PM
Do you know it shouldn't be used? We are already running the
c3750e-universalk9npe-mz.122-55.SE3.bin version so shouldn't
c3750e-universalk9npe-mz.122-58.SE2.bin be o.k?
10-08-2013 02:50 PM
10-09-2013 05:35 AM
thanks
