Cisco 3750 QoS Assistance
Dear Support,
I'm a router QoS person, and am completely lost with Catalyst QoS. Seems to be more wrr/srr rather than class-map and policy-map
Am I missing the point or looking in the wrong place?
Can anyone point me to a guide that shows me the syntax and some examples.
Thanks in advance
I always rate helpful posts.
Regards, Adrian.
Hall of Fame Super Blue
Re: Cisco 3750 QoS Assistance
Hi Adrian
I don't believe the 3750 runs CatOS, only IOS although i could be mistaken.
Attached is a link to QOS configuration for 3750 - IOS based.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a008077444d.html
Jon
Jon,
I don't think Adrian means CatOS. I believe he meant QOS on Catalyst switches and that of course would be IOS on a 3750.
However, the QOS configuration guide link that your provided is correct.
Adrian,
I agree the QOS format isn't universal across every platform and it does vary with the architecture. As you stated SRR or shaped round robin is the queueing method supported on 3750 switches. There should be plenty of documentation and examples available on CCO for you to configure this feature.
Sundar
Many thanks for your responses, so its of to learn another cisco language :-)
thanks adrian.
783
