Cisco 3750 stack problem
i have a switch on a stack that seem not be respond anymore. i tried to restore it to factory default (after removing his stack cables) pressing the mode button. Is there another way to restore it to factory defaults? model is a ws-c3750g-48-ts-e
Re: Cisco 3750 stack problem
To restore this switch to factory default, you can do following 3 steps
Log into the switch using Console
#del vlan.dat
#rease nvram:
#reload
the switch should return to factory default
Shaheen
switch was in fault, we will change it.
was not possible to see the console prompt anyway.
thanks for your help
137
