Community Member
Cisco 3750 Switch Number of Queues for Ingress and Egress without QOS
I am trying to understand the queue setup for the 3750/x switch; I understand that there are 4 output and 2 input queues when qos is enabled; however I am confused on the number of available queues used when qos is not enabled on the switch for ingress and egress?
Not too sure if it may still be 4 output and 2 input queues as I did a show mls qos without it being enabled and it is showing the queues:
Switch#show mls qos interface g1/0/3 queueing
QoS is disabled. When QoS is enabled, following settings will be applied
Egress Priority Queue : disabled
Shaped queue weights (absolute) :  25 0 0 0
Shared queue weights  :  25 25 25 25
The port bandwidth limit : 100  (Operational Bandwidth:100.0)
The port is mapped to qset : 1
Switch#show mls qos input-queue
Queue     :       1       2
buffers   :      90      10
bandwidth :       4       4
priority  :       0      10
threshold1:     100     100
threshold2:     100     100
Any input is appreciated for understanding of the default queues when qos is not enabled on the switch; example does it still make use of 4 egress and 2 ingress queues or a single queue?
1 ACCEPTED SOLUTION
Hi.
Even when QoS is disabled the switch will still show you the four queues. You can issu the command "show mls qos"; note that QoS is disabled.
If QoS is disabled then queues don't have any effect. With QoS disabled you have one ingress and one egress queue.
Regards.
Wilson B.
1 REPLY
Hi.
Regards.
Wilson B.
220
