Cisco 3750 Switch QOS config
Dear all,
   Pls help me to configure qos in Cisco 3750 switch.I have configured below template and applied on the vlan interface.But i am getting the hit on the access list but I am not able to get hit on the class map.pls help to configure properly.
Ajith
1 ACCEPTED SOLUTION
Green
Show policy-map interface xyz stat
Is not support on 3750 lan switches, you can type it if you want but
your stats will not show.
Lets look at your policy
class-map match-any data
  match access-group 105
class-map match-all voice
  match ip dscp ef
access-list 105 permit udp any any
access-list 105 permit tcp any any
access-list 105 permit ip any any
policy-map qos
  class data
   set dscp cs3
  class voice
   set dscp ef
In the policy map the calss DATA will be picked up using ACL 105
Permit udp any -- this will match you voice traffic right away as voip is RTP under UDP
So this means your VIOP is going to get remarked to DSCP cs3
Therfore your class voice is never going to reach ite intended remarking.
I think you would be better trying to catch and mark/remark the traffic at ingress from the ports.
I am guessing that the data you are trying to match is voice signalling. I do not know if the voip system
is Cisco, avaya nortel mitel whatever.
Lets guess that it is Cisco
Some common ports used by Cisco are
Skiiny (SCCP) TCP port 2000
H323 TCP port 1720
MGCP UDP 2427 & TCP 2428
access-list 105 permit udp any any 2427
access-list 105 permit udp any 2427 any
access-list 105 permit tcp any any 2428
access-list 105 permit tcp any 2428 any
access-list 105 permit tcp any any 2000
access-list 105 permit tcp any 2000 any
access-list 105 permit tcp any any 1720
access-list 105 permit tcp any 1720 any
class-map match-any DATA
class-map match-all VOICE
  match ip dscp ef
policy-map QOS
  class DATA
set dscp cs3
  class VOICE
   set dscp ef
int fast 1/0/1
desc *** VOIP & PC Port ***
switchport host
switchport access vlan 10
switchport voice vlan 700
seivice-policy input QOS
srr-queue bandwidth share 10 10 60 20
priority-queue out
int fast 1/0/2
switchport host
priority-queue out
On say port 24 we have a WAN router with a trunk
int fast 1/0/24
interface FastEthernet0/48
description Connected to grangemouth_sw_02
switchport trunk allowed vlan remove 1-1001
switchport trunk allowed vlan add 2,700,999
switchport mode trunk
priority-queue out
mls qos trust dscp
speed 100
duplex full
description *** PORT TO ROUTER ***
priority-queue out
mls qos trust dscp
speed 100
duplex full
On the router port 24 we can check if packets are being marked to the
required DSCPs
sh mls qos int fas 1/0/24 stat
Alex
Regards, Alex. Please rate useful posts.
Green
  match ip dscp ef
policy-map qos
  class data
   set dscp cs3
  class voice
   set dscp ef
H323 TCP port 1720
  match ip dscp ef
policy-map QOS
  class DATA
set dscp cs3
  class VOICE
   set dscp ef
int fast 1/0/1
switchport host
priority-queue out
int fast 1/0/2
switchport host
priority-queue out
int fast 1/0/24
priority-queue out
mls qos trust dscp
speed 100
duplex full
priority-queue out
mls qos trust dscp
speed 100
duplex full
required DSCPs
Alex
HI Alex,
    What will be the impact while applying below commands.
priority-queue out
Also how to verify our outside traffic is marked with ef and cs3 value?I think it wont show in
sh mls qos int fas 1/0/24 stat commad.
Ajith
673
