Cisco 3750 switch with Nortel phones
I am trying to set up a nortel phone with a cisco switch. I have put the port in the trunk modem. The phone works but the PC attached to the phone doesnt. Please let me know what I am missing.
Please rate useful posts.
Re: Cisco 3750 switch with Nortel phones
Can you pose the config?
jerry
The config will be as follows:
switchport access vlan xx
switchport voice vlan xx
switchport mode trunk
Thanks for your response.
Add the following command
switchport trunk native vlan yy
where yy is your data vlan.
HTH,
jerry
Community Member
You don't need to manually trunk the port with Nortel phones, the
will do this for you.
So you only need,
switchport mode access
You need to make sure the Nortel phone settings for the voice and data vlan are the same, either via hardcoding in the phone options or via DHCP options 191 & 128. Have a look at this link
http://people.internet2.edu/~danno/nortel-dhcp.doc
Cheers,
Peter
315
