cisco 3750
Can cisco 3750 just die out after use in a week what is teh cuse of just the fan blowing and no display coming fo rthe switch ports
1 REPLY
Hall of Fame Super Silver
Re: cisco 3750
dhiraj
It is possible that a switch could fail after a week in service. Are there any lights lighted up or blinking on the switch? If you connect a PC to the console port do you get any response or any output on the console? If you connect a PC to the console port and power cycle the switch do you get output on the console? If you will answer these questions we may get closer to solving your problem.
Rick
132
